Niner One 9 RDO chain ring rubbing- Mtbr.com
Results 1 to 9 of 9
    Hi Guys,
    Need some help. Im in the process of building up a one 9 rdo. I have all the parts but have ran into a problem. Im using a sram direct mount crankset ( gxp bb ) with a 32 tooth chain ring. After I installed the crankset, i noticed that when the ebb is in the rear position the teeth on the chainring rub on the chain stay. After searching it looks like i might need to purchase another chain ring with a 6 mm offset. I am not sure what chain ring off set is currently on the crank set now. Is that correct, the 6 mm off set should move the chain ring further away from the frame allowing me the clearance to run the 32 tooth? Thanks in advance for the help.
    Aug 2010
    I think you'll need a Boost chainring with 3mm offset. Or possibly a BB30 with 0mm offset.
    Quote Originally Posted by 06whitetaco View Post
    Hi Guys,
    I'm also curious about this. I just built up a One 9RDO and got the 32:19 to work but couldn't get my oval 32 or 34t chainring to work. With the 32/19 it is closer to the chainstay than I'd like it to be too. Maybe 0 offset ring is the answer but I'd like verification on it before buying more rings I can't use
    I got a 32 chainring with 0 offset from a friend to try out. I will install it in the next couple days and let you know if it works. By the looks of it, i think that will remedy the issue.
    Quote Originally Posted by broeli View Post
    Reputation: coke's Avatar
    I had that problem with my xx1 cranks and a 32t ring. I'm not sure of the offset, but when I switched to an absolute oval, I no longer had any clearance issues and could run my cranks in any position.
    Quote Originally Posted by coke View Post
    I'd like to know your offset on that oval..because when I put on the AB 32t oval I had issues. The big part of oval is like size of 34t chainring. Idk how a round 32 would give issues but not oval 32
    Installed the 32 ring with 0 offset. Plenty of room in any position now. Problem solved.
    I can't find where I read it, but think at some point absolute changed the offset of their rings. It's possible mine is an older version and has a different offset than yours. To clarify I replaced a round 32 with an oval 32 (34 at largest point).
    I think buying the boost version of their rings would solve your problem.
    Yep I did the same. Used a bb30 0 offset oval and there is plenty of clearance. I think a 3mm offset would also work. The chain line needs adjusted a little imo using the 0 though..space rear cog out a little more
  1. Replies: 3
    Last Post: 03-17-2016, 12:05 PM
  2. Chain ring bolts rubbing-help
    By SeaTown in forum Vintage, Retro, Classic
    Last Post: 04-28-2015, 10:16 AM
  3. Single chain ring vs stock middle ring and chain slap
    By Terranaut in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-07-2014, 11:55 AM
  4. Replies: 10
    Last Post: 08-13-2012, 06:34 PM
  5. Replies: 3
    Last Post: 03-04-2012, 08:40 PM
