Newbie Questions -have read faq- Mtbr.com
    New question here. Newbie Questions -have read faq
    I have read the faq but i still have some questions. iam building my first single speed with a gary fisher hardtail. i have a tensioner (surly) chain, spacers, bmx cog just need cranks the ones that came on the fisher are acera or something like that. where is the cheapes place to get some cheap cranks that will work. iam pretty excited about going on a singlespeed never have done. in my area there are few probably can count on one hand... also can someone post a pic of using spacers on their rear hub..i have seen the ones in the faq but iam still confused..thanks in advance..
    semi-evolved simian
    Reputation: Mine'sAPint's Avatar
    Quote Originally Posted by mikieboy
    I had the same problem with the cheap rivetted chainring/cranks on my old SS convert. I ended up picking up some older XT crankarms on ebay - they work great!
    Cracker-magnon
    Reputation: gpsser's Avatar
    here is a spacer pic
    Hope it helps. You will prolly not want to set up the rear wheel until you have the cranks so the chain line is straight.
    "Life is a [email protected]#^ing story problem, get used to it - my son.
    New Cranks?
    I just need cranks the ones that came on the fisher are acera or something like that. where is the cheapes place to get some cheap cranks that will work. ..
    What is wrong with the old cranks? Get some shorter chainring bolts and use the middle ring.
    "I've never been better .... nor cared less!"
  1. Slime tube newbie questions
    By AZBound in forum Arizona
    Last Post: 03-09-2004, 02:01 PM
  2. SS newbie questions
    By bob in forum Singlespeed
    Last Post: 03-03-2004, 10:20 AM
  3. mark forum read...suggestion
    By warmseth in forum General Discussion
    Last Post: 02-10-2004, 04:40 PM
  4. Newbie SS'er has two questions....
    By []D[][]v[][]D in forum Singlespeed
    Last Post: 01-26-2004, 01:22 PM
  5. Newbie DH racing questions
    By COmtbiker12 in forum Downhill - Freeride
    Last Post: 01-26-2004, 12:34 PM
