Newbie: Freewheel or Cassette Cog?- Mtbr.com
Results 1 to 9 of 9
    Reputation: irieite's Avatar
    Jan 2005
    I have two wheels that I can use. One has a freewheel hub, the other a 8/9 speed cassette hub. My question is, which is the better route to take for a single speed? I know that you can fine tune the cog spacing with the chain line on a cassette hub, but what about with a freewheel?
    Reputation: Sideways's Avatar
    Feb 2005
    Cassette hubs allow easy chainline adjustment.
    FW hubs like the surly are WAY TOO OUTBOARD to adjust.
    (Its like "I keep adding spacers and its still too wide")
    -Marshall Hance
    EndlessBikeCo.
    Jan 2005
    New question here.
    It would seem to me that putting a single speed freewheel on a wheel design for a multi speed frewheel, would be more inboard than outboard. That is, it would be closer to the hub and way out of the chain line. Is this not correct?
    Feb 2005
    Quote Originally Posted by irieite
    If that's what it is, then it needs respacing, redishing, and then some FW spacers...and at that point you can do with it whatever you want and it be a pretty cheap way to get things going. But dang, if that's the case I would just buy some spacers and a cog and be done with it on the cassette hub. Respacing FW hubs can be obnoxious. Besides, cassette hubs have stronger bearings than fw multigear hubs
    -Marshall Hance
    EndlessBikeCo.
    Reputation: pacman's Avatar
    No. Freewheels and freehubs are not interchangeable. A freehub is the Shimano invention that holds a cassette.
    Jan 2005
    Right. I have both a freehub and freewheel, wheel that I can use, I'm just trying to decide which is the better route to persure, being that I haven't bought a singlespeed cog or freewheel for them yet.
    go with the casette freehub.
    Suggestion
    I don't know if it's 'better', but the less expensive way to go would be to buy a few different sized cogs for the freehub with spacers and see what gear ratio fits.
    Hopefully the freehub is steel so you can use the $5 novatec/ DX cogs. If it's aluminum, you'll need to look for a wide based cog, which is a bit more $$$.
    -Richard
    Jan 2005
    Thanks for the replies. Looks like I'll go with the freehub cassette cogs and spacers. Seems to be the easiet way to go.. I do however have an aluminum freehub, so looks like I'll have to go with more expensive wider cogs to keep from damaging it.
  1. 12-34 cassette w/ no little ring, or 12-27 cassette?
    By stumpy2324 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 11-01-2004, 03:35 PM
  2. Creaking from a new cassette - help
    By dgangi in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-13-2004, 09:41 AM
  3. R der. upper pulley hits largest cassette cog when in that gear
    By duder in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-20-2004, 06:19 PM
  4. Newbie question regarding cassette
    By []D[][]v[][]D in forum Singlespeed
    Last Post: 03-09-2004, 11:15 PM
  5. should I use my old freewheel hub?
    By jbmoocow in forum Singlespeed
    Last Post: 02-18-2004, 07:47 AM
