New SS Build: Crank Help- Mtbr.com
Results 1 to 6 of 6
    I'm going to try my hand at some SS racing this season and in building up a new frame set as a treat to myself. The only component that will not be coming over from my current bike is the crankset. I'm looking to upgrade. I'm considering the new 9000 series XTR 1x crankset. Is there any reason this would not make a reliable SS specific crank? If it's not a worth crank are there any suggestions? Thanks in advance.
    May 2005
    It would probably work, but I personally wouldn't use it because it has a funky BCD (bolt circle diameter). A better choice would be an XT or SLX triple 10 speed crankset that uses a 104mm BCD. There are tons of choices for chainrings with that bolt pattern. Just sell the stock chainrings on Ebay and buy a single speed chainring and some shorter chainring bolts. This is usually more cost effective than trying to buy a 1x crankset plus you get to pick your own chainring tooth count (and color if you want bling). A triple works better than a double due to the chainline optimization around the middle ring.
    the air is thin up here..
    Reputation: noot's Avatar
    I like my XO cranks. The spiderless design is nice with more selection than ever, and you can go as small as you'd like.
    2017 Transmission Smuggler
    2015 Kona Paddy Wagon
    www.mngnt.com
    WillWorkForTrail
    Jun 2012
    SS cranks? The first set of cranks I had came on my first SS. They still work (going on a new build for my son) but they're a little heavy. The next set I bought off a friend of mine (new take-offs) are Raceface cranks, much lighter, they also do the job. What I'm getting at is, any reliable crankset will work. I like the Shimano triple suggestion just for the reason it's recommended - so many 104 options out there.
    Downcountry AF
    Oct 2013
    i would check out a direct mount crank. Raceface cinch system makes a lot of sense to me. very versatile crank, it can do just about anything you want.
    Rigid SS 29er
    SS 29+
    Fat Lefty
    SS cyclocross
    Full Sus 29er (Yuck)
    Love my Race Face Next SL's for diversity and ease of change.
  1. Replies: 17
    Last Post: 01-27-2015, 01:33 PM
  2. Crank and BB for '96 GT Budget Build?
    By lucky53s in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-26-2014, 05:25 AM
  3. Need crank/BB advice for a Muk3 build...
    By Bacons in forum Fat bikes
    Last Post: 01-12-2013, 05:20 AM
  4. New Build 29r Crank question
    By tailwaters in forum 29er Bikes
    Last Post: 11-28-2011, 08:37 PM
  5. Crank The Shield: Trail Build
    By garage monster in forum Eastern Canada
    Last Post: 08-15-2011, 04:15 PM
