New rear hub.- Mtbr.com
Results 1 to 3 of 3
Thread: New rear hub.
    New rear hub.
    I can't seem to find any definite answer on this. I need to replace my rear wheel and wanted to stick w/ a cassette style but all of the good ones seem to bit high priced. I would be willing to go to a freewheel style but am having trouble finding an a freewheel in bigger size, 22-23 tooth. I'm a big guy, 6'3" 215lbs and was wondering if I would be sacrificing strength if I went with a geared hub w/ a conversion kit. Any help on this would be appreciated.
    Reputation: henrymiller's Avatar
    Why not use a larger ring and thus a smaller rear cog/freewheel?
    Roscoe's Chicken 'n Waffles
    Reputation: rzims's Avatar
    I'm guessing if the OP is looking for a larger rear hub, then he's going to want it to be easier to pedal, thus a smaller front ring? I could be wrong....
    Regarding the question of strength, I used to run a cassette rear hub with a surly cog - though not quite as big as you I push 200lbs plus gear and never had an issue....
