New bike build, recomendations on gearing...- Mtbr.com
Results 1 to 7 of 7
    Reputation: need4gforce's Avatar
    Im going to be running 180mm eno cranks, I am 6'2 and Have rode bmx from 10-20, now 5 years later and a little weaker I want to know your opinions on gearing.
    The million dollar question. Where do you live and what kind of terrain will you be riding?
    Quote Originally Posted by need4gforce
    Yeh i thought about that after I made the post.
    I live in Northern VA, I hope to ride to the store and back sometimes like 1 mile lol, and I would like to try out the trails at fountain head park.
    Reputation: NorcoNate's Avatar
    I run 33/17 on my niner. it doesn't spin out too easily on the flats and i can climb most hills i've ridden, but thats if you have the muscles for it. lol. i started out with 33/20 and it was nice for climbing, but the flats u'd spin out way too easily.
    HMMMMMM....Eno chaing rings only come 32 or 34 they dont make a 33 those bastards....
    Right now I havnt orderd a chainring but I do have either a 18 or a 20 tooth cog to use.
    Im thinking money savings wise it would be better to go with the 34..... try 34x18 and if im to much of a ***** I will put the 20t on and see how that is....
    the 34/18 will be a close ratio to the 33/17 i run. or you could go with a 32/17 which is about the same ratio as the 34/18
    fnInt(1/x^2,x,0,1)
    Reputation: fleanutz's Avatar
    I've ridden Fountainhead (though on my geared bike). If you're planning on SS there you better try 32/20 first since you've not ridden much. Some of the climbs out there are pretty steep and loose.
