Need some input from Geometry wizards- Mtbr.com
Results 1 to 8 of 8
    A plain old rider
    Reputation: The Tree's Avatar
    I finally have dialed in my perfect gear ratio 1.94:1 (using 33t chainring and 17t freewheel), but there is one problem. When I am climbing loose rock spots in the trails I ride the back end slips a little more than I would like. The normal answer would be to use a 16t freewheel so that there is less torque (this may be wrong).
    The question I have is, if I had a frame with a longer top tube and used a shorter stem to have the same effective top tube length would more weight be shifted back to the rear wheel when I stand to climb? Or would I have the same problem?
    Dave
    The greatest gift you ever give is your honest self.
    Fred Rogers
    Chatham NJ
    Have you tried just leaning back a little more. Or have you tried a different rear tire?
    A plain old rider
    Leaning back does work, that was the principal for the question. The problem is that it is less comfortable for extended climbs. As for the tire (Paneracer fire), it hooks up so good on everything else I dare not change it, but I have tried several other tires in the past.
    Fred Rogers
    Reputation: pacman's Avatar
    You'd have a heavier bicycle but the weight on the rear is almost the same.
    On the plus side you could counter-pull the bars harder since you'd be less likely to wheelie.
    Out spokin'
    Dec 1999
    Quote Originally Posted by The Tree
    Dave
    The TT length/stem length thing is moot.
    You don't say whether your slipping problem is while you're standing or sitting, but in either case you'd be better served by shorter chainstays. These will bring the rear wheel closer to the cranks (where your weight is while standing) and closer to the seat (where your weight is while sitting). Additional weight on the rear tire will help improve traction.
    Yes, a taller gear will help you spin less, so long as you are strong enough to push it. I like to combine a taller gear with a longer crank. Torque is increased but so is the ability to effectively meter that torque due to the longer lever/crank.
    --Sparty
    disciplesofdirt.org
    Reputation: gonzostrike's Avatar
    Agree completely w/ Sparty.
    He's said all the big important points on this question.
    Reputation: shiggy's Avatar
    Dec 1998
    --Sparty
    Seat tube angle is a factor, too. Given the same tt/stem length and chainstay length, a laxer ST angle will put more weight over the rear while seated and farther forward when you stand.
    mtbtires.com
    A plain old rider
    Thank You
    Thanks for all the input. It really shows how complex subtle changes in geometry can change a bikes handling.
    Dave
    Fred Rogers
  1. Replies: 17
    Last Post: 02-14-2005, 07:12 AM
  2. CA Id vs. Reg Id geometry
    By MrStraw in forum Ellsworth
    Last Post: 05-02-2004, 05:45 PM
  3. Bullit - geometry adjusts? Which works for you?
    By yoonior in forum Santa Cruz
    Last Post: 04-14-2004, 06:48 AM
  4. Platform shock bike geometry?
    By Spice52 in forum Shocks and Suspension
    Last Post: 03-22-2004, 09:17 PM
  5. Replies: 1
    Last Post: 01-12-2004, 07:32 AM
