need help peicing together a drive train.- Mtbr.com
Results 1 to 9 of 9
    Nov 2015
    my bike is a 2013 kona splice setup with a 3x8 system. right now I've got a 16t cog conversion kit, a black spire stinger,( as my chain tensioner), narrow chain ring nuts, kmc 710 half link chain and a blackspire 96mm abcd narrow wide m8000 ring gear. problem being the asymmetrical bolt pattern.
    now I was told half links aren't that good of a chain to have and that with singe speed a narrow wide isn't needed, but I am limited to a 96mm bcd with my current shimano m612.
    Reputation: joshhan's Avatar
    Mar 2011
    You can't run a NW ring with a half-link. You don't really need it for a SS anyway. Just get a new (regular) chain and you should be set.
    Bikes, lots'o bikes
    Nov 2015
    Ya just there isn't a whole lot of selection with 96mm bcd. narrow wide is my only option feesably. And that i bought the m8000 chain ring itd be cheaper in the long run to get the boost spec crank set.( on the principle of building a boost spec as hardtail in the future)
    so I'd like and think that using boost cranks with a ss will work. Since boost would need less outward shiming for proper chain line right?
    Jan 2009
    Why bother with a boost crankset? Get a standard crankset with a 104 BCD and it will work for years and years.
    Feb 2017
    Ditch the half-link chain and get a normal KMC Z610. You don't need a narrow-wide chain-ring, but it won't hurt as long as your using a normal chain. I'm running them on my single speed and my dingle speed because they were the cheapest option.
    Nov 2015
    No going back now. I got a regular chain kmc x1 and the corresponding crank set. Only thing now is lining up the chain line.
    Reputation: Mark194's Avatar
    Mar 2012
    Hey Neon -
    Putting together my first SS. I am using a Surley rear cog with a Narrowwide 11 speed front Chainring. Will this chain work?
    thanks!
    Quote Originally Posted by NeonRyder View Post
    Feb 2017
    Quote Originally Posted by Mark194 View Post
    Hey Neon -
    thanks!
    Are you talking about the Z610? Thats basically what i'm running on mine. Surly rear cog and narrowwide front ring.
    Mar 2012
    Yes, thank you!
  1. Replies: 5
    Last Post: 07-10-2014, 05:47 AM
  2. Replies: 7
    Last Post: 06-26-2014, 05:09 PM
  3. need advice on drive train setup
    By 4runner2901 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-03-2013, 12:31 AM
  4. need new drive train - replace same or get new/different?
    By teleguy03 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-09-2013, 08:01 PM
  5. Drive train problem, need your advice
    By spec d in forum General Discussion
    Last Post: 07-16-2011, 10:58 PM
