need help with kick ass cog!!!- Mtbr.com
Results 1 to 9 of 9
    Eli Broccoli
    Reputation: 123elizxcvbnm's Avatar
    I just got a new kick ass cog and i can't seem fit it on my new ztr freehub body. any suggestions?
    Wo, wo, wo, easy with all the unnecessary detailed info. Briefly tell what's wrong with zero details.
    bustin chops. Seriously, post some details and pics.
    Eli Broccoli
    Its an endless bikes K.A.C. I'll try to post these pics. anyone have this problem before?
    Eli Broccoli
    screw it
    the dremel will have to do
    nothing to see here
    Reputation: Stevob's Avatar
    I had trouble with mine, but it was going onto a threaded shortened cassette freehub on a Kona Unit. Just needed a little light tapping to get it on.
    A dremel might take too much off and leave it loose. Maybe try some sand paper first.
    I see hills.
    I want to climb them.
    Eli Broccoli
    thank you
    its nice to know i'm not just a dummy......in this situation at least
    I had the same problem and used a small metal file only took off as little as needed.
    Same problem. Bought the cog to use for a race and I couldn't get it on the freehub the night before. Don't need the cog anymore so I may return it and get a Homebrewed.
    Reputation: Dscarbs's Avatar
    same issue on my hope hub... about 5 minutes and some sandpaper made it fit perfect.
