Need advice from Unit owners- Mtbr.com
Results 1 to 9 of 9
    meow
    Reputation: Cato's Avatar
    I just came into posession of one Kona Unit . Lots of fun!!!! However, the brakes on it are Avid SD 5's, and the rear brake arms are very close to the tire and wheel, making adjustments a beatch. I'll replace them with rim brakes and am looking for any suggestions of brands and models that work well on the set up. And don't say "go discs!"
    Reputation: EMFC's Avatar
    Go Discs! I just couldn't help myself
    "A full rigid SS or fixie is 99% rider, 1% bike, and 100% more fun" Monogod
    Rollin' a fatty Moderator
    Reputation: DiRt DeViL's Avatar
    Can't help you, I use disks.
    Reputation: pacman's Avatar
    I went discs. Tired of adjusting the brakes every time after moving the slider plus the braks arms could stick way out.
    Au'Right!
    What spacers are on the side closest to the pads? Is it the thick one or the thin one, if you know what I mean?
    Problem: "Bike has trouble going up steep hills."
    Fix: Recommend pressing harder on the pedals.
    Reputation: lane's Avatar
    Mar 2006
    I'm running Avids on my Unit and clearance isnt a problem. As was mentioned earlier, it sounds like you have the wrong spacers on the pad bolts.
    meow
    Hmmm...the spacers on these do seem thicker than the ones on the Ultimates I have on the full suspension. Are thinner spacers available? Now I'm thinking about going to discs....hmmmm. I said discs!
    from the east
    Reputation: Bicycle Rider's Avatar
    Spacing.
    As others have said, I too think your pad spacing is off. Easy to fix. Take a look at the manual for your brakes:
    http://www.sram.com/_media/techdocs/...-5-install.pdf
    If that's your problem, you'll be off and running in 5-10 minutes. Just make sure to adjust the pads properly after switching the spacers. (This is also covered in manual.)
    eric.
    What power?!?
    The power of Voodoo!!!
    meow
    Thanks BR for the spacer advice. It helped some. I made all the appropriate adjustments, but still had to let the cable out some to get the proper spacing.
