My winter home grown project....- Mtbr.com
Results 1 to 9 of 9
    It's been sitting at my house for months and I finally decided to build her,
    Schwinn Homegrown frame. I am missing wheels, brakes and cranks.
    Could I have an EBB installed on this frame?
    I would like to use disk, if not I'll just go w/ an eno hub and v-brakes.
    I don't want to wait till next year for the eno disk hub.
    some more...
    mocked up w/ the parts I'm using, (minus the wheels)
    Cracker-magnon
    Reputation: gpsser's Avatar
    Spicer does ebb retros on alum frames, but with the construction of that chainstay yolk at the bottom bracket, I would think it would be difficult at best to do that frame. You could always contact him with a picture and see what he has to say.
    "Life is a [email protected]#^ing story problem, get used to it - my son.
    I think you can grind about 1mm off your axel to make a 34/16 work without a tensioner. I used that ratio and just resorted to not having the axel totally bottomed in the dropouts.(01 Homegrown Comp) But had I done the axel grind, my life would have been much easier. When I say "grind axel" I mean to make a flat spot so the axel will go slightly forward in the dropout. Sort of like making the axel a D rather than an O if you know what I mean? Then line up the flat spot facing the front of the bike and axel will drop right in place with perfect chaintension. And as the chain slackens with wear, turn the axel a bit. Cheaper than a new hub for sure.
    My tapeworm tells me what to do.
    Reputation: SSSasky's Avatar
    New question here. why not ...
    run a tensioner until the eno disc comes out?
    something like the rollenlager is pretty discreet if used in the push-up position, and damned burly.
    then you can run disc, instead of having to buy v's (assuming you already have the disc brakes)
    or what about a half link instead of filing the axle?
    I meant 34/16 not 34/14 I edited my post, just wanted to point out the correction. 34/14 is for mutants or extreme flatlanders. And I have no idea how much chain slack you'd have with 34/14.
    34/16 is just so darn close, running an extra link and the tensioner wasn't possible. I had chain hop on my rear cog. And push up wasn't an option, too much chain. Thats why I ended doing what I did, it was just so close to being a majic gear. Had I known to file the axel... Oh baby...
    I think i'll try a 32/18 w/ a half link and try to make it work. If not I'll just buy a cheap tensioner. I've been using a 32/18 on my geared bike and I seem to make it up most hills so I wanted to use something similar.
    Quote Originally Posted by Rude-e
    looks sweet. I've always liked the looks of that frame, although I've never ridden one. I'd actually like to pick one up to replace my geared ride. enjoy it, it looks really nice.
    The Top Cap Guy
    Reputation: Fast Freddy's Avatar
    This is Too Funny!!! I just bought another Homegrown (my 2nd) strictly for a SS conversion. I originally had a Bass Boat Blue full suspension I was going to do - ended up selling it complete and just aquired this frame. I believe it is a 2000. I've been picking up parts as I go - but I'm in no rush to complete it - just by spring. I'm thinking a Pace RC31 fork, and Raceface cranks, and some disc wheels of somekind - not sure yet - some sweet orange rims would be cool though. I want to run it tensioner-less, and I will suffer with whatever ratio works. It's going to be an extra SS for me so I can always run the other bike in different gears. Last time I talked with Gene about aluminum EBB conversions he didn't like the idea of super light butted tubes - which these frames have, as well as the machined yoke behind the bb. He offered to try - but wanted to see it first. I'll just keep trying until I find a magic ratio.... and anyone reading this if you have or know where to get Homegrown accessories (would love a replacement decal set) like seat clamp, etc... drop me a email.
    Thanks and good luck (keep me posted)!
    FF
    PS - here's my project.....
    "If I'm leading, I'm bleeding."
  1. My Winter Project came in the mail today....
    By TheBUNKY in forum Singlespeed
    Last Post: 02-03-2005, 06:42 PM
  2. Winter project?
    By TroutBum in forum Singlespeed
    Last Post: 01-17-2005, 07:55 PM
  3. Replies: 5
    Last Post: 10-27-2004, 11:39 AM
  4. Looking for a winter build project?? (Spam)
    By gofarther in forum Weight Weenies
    Last Post: 10-06-2004, 06:38 AM
  5. Biking Related School project ideas....can I get some help?
    By COmtbiker12 in forum Downhill - Freeride
    Last Post: 05-13-2004, 09:27 PM
