My Singlespeed Project(Finally Finished)- Mtbr.com
Results 1 to 13 of 13
    Shred
    Jun 2010
    I am running a 30:16 setup and climbs just fine. This build took me forever because this tech sold me used disc brakes with V Brake bolts already on it. I couldn't figure out what kept catching my rear wheel. I will post some close ups soon!
    Attached Thumbnails Attached Thumbnails My Singlespeed Project(Finally Finished)-mtb1.jpg
    Axles of Evil
    Reputation: SS-Dad's Avatar
    Your front wheel is facing the wrong way. The rotor tabs should face the left fork leg. Looks pretty cool.
    Come see me after class
    Dec 2005
    Quote Originally Posted by xUSER_NAMEx
    i would hope so. that's pretty short.
    What could go wrong ...
    Reputation: Zoke2's Avatar
    Nov 2007
    and whats up with the seat height ... are you using it for dirt jumping or something?
    I used to ride to Win ... Now I ride to Grin
    While my guitar gently weeps, my bike sits there mocking me
    Shred
    Jun 2010
    Seat is lower for maneuverability in trails I raise it for commuting and stuff.....Yeah the front tire is weird....the tab gets stuck on the bottoome of my motion valave at the bottom of the forks ....anything you can suggest?
    Nov 2007
    "the tab gets stuck on the bottoome of my motion valave at the bottom of the forks ....anything you can suggest?"
    what tab ... do you mean the QR lever? .... if so, just put the skewer thru the other way (the way you have it but turn the wheel around) because the mounts for the rotor shouldnt be a problem on the left side
    Shred
    Jun 2010
    More photos...
    Ok, here are some updated photos of my first build. Let me know what you think!
    Attached Thumbnails Attached Thumbnails My Singlespeed Project(Finally Finished)-p1011313.jpg
    one chain loop
    Reputation: fishcreek's Avatar
    looks nice, just fix the front tire rotation.
    everything sucks but my vacuum cleaner.
    Shred
    Jun 2010
    Both hubs are on the left side.....is that not right?
    I can tell by the tire tread pattern that your front wheel needs to flipped around.
    Shred
    Jun 2010
    ok...so its the actual tire that needs to be turned around... DUH! thanks dude!!
    Yeah, check the direction arrow on the tire's sidewall. Awesome build by the way. I like Access (even though they are a bit heavy). Performance has those frames for a very competitive price!
    Shred
    Jun 2010
    Thanks man thats one of the main reasons I went SS. The frame itself is surprisingly only 3.8 lbs its pretty decent just under 30 lbs It may even be lighter.....killer on inclines and will probably never go geared again. I think my chain ring is a bit bent though which blows because its brand new...it has this weird uneven spin that I never noticed until today
