More travel, more smashing?- Mtbr.com
Results 1 to 17 of 17
    May 2013
    Hi all,
    This past weekend I took my Honzo SS on The Hole in the Ground Loop near Tahoe:
    https://www.mtbproject.com/trail/147...he-ground-loop
    It gets relatively chunky with granite slabs on the climb and the flow sections and a series of step-downs on the descent. I rode with a 120mm Pike, and while it was fine, I did find myself slowing down as I approached the chunky stuff, so I'm wondering what I could do if I extended the Pike to 140. I don't anticipate the 140 causing a problem by slackening the seat tube angle since I'm not really climbing seated. And I'm excited about the potential for fewer pedal strikes, because I get a fair number of them if I'm not careful to ratchet on chunky stuff. But I wanted to see if there are other factors I'm not considering when changing the fork travel. The only downside I can think of is a change in reach. The Honzo's reach (510mm in XL) has been perfect for me when standing climbing and descending with a 50mm stem. I figure that if the reach shortens by 10 mm, I could try a 60mm stem, but that's easy to address.
    I see many other trail-oriented SS rigs on this forum with 140mm forks. How do you folks like them as ride-everything bikes? Do you notice any downsides, or even just changes, compared to your shorter-travel SS setups?
    Thanks in advance for your thoughts.
    Jan 2009
    I recently went from a 120mm Reba to a 140mm Fox 34. I honestly can't tell the big difference in travel, but the fork is much stiffer. I have parts to drop it to 130, which I'll probably do the next time I drop the lowers.
    The Honzo has a pretty low BB, right? I would think the longer fork would be worthwhile just to get the pedals away from the ground a bit.
    Wanna ride bikes?
    Oct 2013
    140mm on a Honzo ST would be awesome, no real drawbacks aside from being slightly slacker and longer wheelbase. You may need to make a small stem/spacer adjustment to maintain your handlebar position.
    Rigid SS 29er
    SS 29+
    Fat Lefty
    SS cyclocross
    Full Sus 29er (Yuck)
    It's worth a try, air shafts are cheap!
    Another thing to consider is arm and core strength. 20 mm of travel only buys so much, especially on a hardtail. If you can stay in control of your mass on the bike you can go much faster.
    Also practice!
    Stache 7 --- Rigid Surly 1x1 B+ --- Dirt Drop CrossCheck
    WNC Native
    Reputation: nitrousjunky's Avatar
    Honzo is much better on a 140mm fork than 120mm.
    "I ride to clear my head, my head is clearer when I'm riding SS. Therefore, I choose to ride SS."~ Fullrange Drew
    Reputation: OLDFATUGLY's Avatar
    Apr 2014
    I have been on a Honzo St/ss with a pike 140 since Dec Ď16. About a perfect bike for me.
    Out spokin'
    Dec 1999
    My '13 Honzo has been sporting a 160mm fork for the past 5 years or so.
    My next hardtail (29x3" custom currently being built) will employ a 170mm fork if this tells you anything.
    Don't fear the reaper.
    =sParty
    disciplesofdirt.org
    Ovaries on the Outside
    Reputation: umarth's Avatar
    Quote Originally Posted by Sparticus View Post
    =sParty
    Jesus ****ing Christ. How high is the bb on the custom? Who is building it?
    Out spokin'
    Dec 1999
    Quote Originally Posted by umarth View Post
    Addiction Cycles. Titanium.
    Did you know a custom framebuilder can make BB height whatever they want it to be?
    Don't start with me again, umarth. It's been a long time but we've been down this road before. In fact I only recently ended my counseling sessions following those years. I'm asking nicely.
    =sParty
    P.S. I'll tell ArchMarge. She & I still, you know, talk.
    disciplesofdirt.org
    May 2013
    Youíve all persuaded me to try going bigger with the fork...
    Wanna ride bikes?
    Oct 2013
    Quote Originally Posted by jamesdwebber View Post
    Well, what do you mean by that?
    Don't get too carried away, keep in mind the people responding here may ride very different terrain than you. I'd set it up for what suits your local terrain.
    Rigid SS 29er
    SS 29+
    Fat Lefty
    SS cyclocross
    Jan 2009
    Subscribed.
    =sParty
    I was just asking because I know you like using 400mm cranks. But since you are going with titanium I'm guessing you went shorter so you don't crush the bb like a beer can.
    Out spokin'
    Dec 1999
    Good memory. Iím kinda over the long cranks these days although my current singlespeed (Kona Honzo) is equipped with 185mm cranks. This new sled will be geared and employ 170mm cranks. I couldnít find any longer in 83mm spindle length. The frame will also sport a 157mm rear axle to accommodate the jumbo wheels. And a 190mm headtube. And a 210mm dropper. Some radical ideas went into the design; hope I like it.
    All kidding aside, letís go riding sometime. Itís been too long.
    =sParty
    disciplesofdirt.org
    =sParty
    Nice, are you going to jump into 29+? I've been riding a Krampus for a couple years now (without that yucky suspension) and it is mostly perfect for our neck of the woods.
    We can go riding just as soon as my ACL and meniscus aren't torn.
    Out spokin'
    Dec 1999
    Yes. Decided to close my eyes and fall backward into the arms of 29+ totally on trust. I've never even ridden one. But damn, I know I love big wheels. My FS sled sports 29x2.6" meats (WTB Vigilante front, Schwalbe Magic Mary rear) and I say with certainty these are the most trustworthy, confidence inspiring tires I've ever experienced. Just enjoyed a 5-ride weekend (4 of the 5 rides shuttled) which included 10,000' elevation loss and felt solidly in control 100% of the time. Very nice. Eager to try the 29x3" tarzan wheels.
    P.S. Tried 27.5x3" wheels... just wished they were bigger around.
    Get them body parts of yours untorn and let's hit it, my friend. Maybe Sizzler can join? And Marge? Time to get the band back together.
    =sParty
    disciplesofdirt.org
    Sounds like a sweet ride. I think you will love the 29+, just make sure you have a bigger rotor up front because the big wheels keep on turning, even when you don't want them to.
  1. Carbine? Smashing lower pivot
    By kburati in forum Intense
    Last Post: 10-28-2018, 11:41 AM
  2. I keep smashing my bars!
    By DethWshBkr in forum General Discussion
    Last Post: 11-15-2015, 08:15 PM
  3. Santa Cruz Carbon Smashing
    By sherijumper in forum General Discussion
    Last Post: 03-07-2012, 06:57 AM
  4. OT (obviously): Who Here is into Smashing Pumpkins?
    By highdelll in forum General Discussion
    Last Post: 10-29-2011, 08:45 AM
  5. Passion Smashing
    By MysticFalcon in forum Riding Passion
    Last Post: 07-28-2011, 05:23 AM
Members who have read this thread: 95
