Monocog - Largest rear tire??- Mtbr.com
    anybody know what's the largest tire size the monocog will take in the rear?
    The beatings will continue until morale improves.
    SS Clyde 29er
    Reputation: fire horse's Avatar
    my friend put a 2.4 on there but had to pull the sucker..
    way back, i dunno if this will work w disk brakes tho. id take ur rig on down to the bike shop n test out what u want before u commit to something that may not fit. good luck fellow monocoq pilot! RAGE ON !
    cause it's fun
    2.1's work best for me...2.2's will fit, but if you ride through mud, it will suck. 2.3's will come very close to rubbing the frame, unless you run the back tire towards the end of the dropouts.
    bus driver wanna be
    Reputation: jdub347's Avatar
    Quote Originally Posted by sperry
    I am running a 2.1 Epicwolf and had to run the wheel back farther in the dropouts. You may be able to run a 2.2 if you ride in dry conditions.
  1. If you need to know this.
    By KevinVokeyJ24 in forum General Discussion
    Last Post: 12-24-2004, 09:40 AM
  2. monocog + rear tire ???
    By isburns in forum Singlespeed
    Last Post: 04-22-2004, 09:37 AM
  3. Blur rear tire choice thread from old boards
    By CraigH in forum Santa Cruz
    Last Post: 03-03-2004, 05:16 PM
  4. Rolling resistance front vs. rear tire?
    By keen in forum Wheels and Tires
    Last Post: 02-21-2004, 05:17 PM
  5. Biggest rear tire for the Superlight?
    By Earthpig in forum Santa Cruz
    Last Post: 02-12-2004, 12:20 PM
