misfit psycles cog- Mtbr.com
Results 1 to 8 of 8
    gmx
    gmx is offline
    Nov 2006
    misfit psycles cog
    Thinking of picking up a couple. Anyone one had any expereince with these?
    Misfit Psycles
    Reputation: nogearshere's Avatar
    Mar 2005
    Quote Originally Posted by gmx
    yummy.
    of course, i'm biased.
    Expert of the Internet.
    BECAUSE I SAID SO
    Reputation: ernesto_from_Wisconsin's Avatar
    actually...
    Quote Originally Posted by nogearshere
    yummy.
    I need a 16t for my one and only non ENO wheelset.
    Reputation: stevereeneo's Avatar
    Good job! So far so good on mine!
    I've been using my 20t for about 3 weeks and it is "like butta'!"... smooth as silk. But with only a few weeks it still has that Canadian new cog smell - so time will tell. It took some steep climbs a few days ago without any complaints - steep enought that I had to stop mid hill, turn around and charge at it again ...
    S
    "You know how they make aluminum bike frames? They take steel and suck out all the soul..."
    Back on the wagon
    Reputation: PutAwayWet's Avatar
    been using an 18t for over a year - no complaints whatsoever. I like it cause it's got a wide stance, like that 'not gay' congressman, so it doesn't damage my freehub (ti Hadley). In the year I've ridden it, it really doesn't show any wear - although I am a bit OCD about lubing my chain.
    RIDE HARD, live easy.
    Keep on Rockin...
    Reputation: Miker J's Avatar
    Nov 2003
    Well...
    The guy who runs the operation is very good to deal with.
    I have 3 of the cogs.
    Two are out of round (one slightly, one pretty bad) that creates run-out like an off center crank or chainring. The other is good. The best thing is that the teeth are nice and tall which helps prevent chain-drop. Too bad about the 2 that are out of round because they are otherwise very nice cogs. I'm quite certain it's the cogs as I've played around with all the other factors and the "common denominator" is clearly the cogs.
    Misfit Psycles
    Mar 2005
    Quote Originally Posted by Miker J
    i won't say never, but i will say these would be the first.
    send the 2 outta wack back, i would like to measure myself (you understand), if they are messed up I will send you 3 good ones back.
    drop me an email [email protected] to confirm when you do send them.
    BECAUSE I SAID SO
    Keep on Rockin...
    Nov 2003
    How's that for service...
    Like I said the guy is "very good to deal with".
    I'll send the one that has the most runout back. The one that was only slightly out was still good enough to use and I put miles on that one already. I'll shoot the one back to you and if you find it out of round a single replacement would be more than enough.
    I'll shoot you an email.
    Thanks,
    Mike
