Midge bar questions- Mtbr.com
    Reputation: Potential Roadkill's Avatar
    Midge bar questions
    I've read more than a few people rave about the Midge bars, my question is about stems, what angle do you recommend, (I understand that a riser stem is important with these) and did you need a shorter, or longer stem that you would reide with a flatbar?
    29er Fan!
    DiscoCowboy
    Reputation: Allroy's Avatar
    Hard to recommend
    something so arbitrary, but for reference, I went from a 5º rise with bullhorns to a 40º and a 1/2" spacer up.
    Quote Originally Posted by Potential Roadkill
    Needed Less ~ Did More
    Reputation: Singlespeedpunk's Avatar
    You need a stem that will get the drop-section of the bar near enough where your flat bars are...if the frame is not designed for off-road drops (ie huge long head tube) you will probably need a 30-40deg stem.
    Look at this set-up guide from the man himself
    Alex
    "Put any one on one of these singlespeed bikes and they could not help but have fun"
    Otis Guy talking about klunkers c1976
    FTM
    FTM is offline
    Reputation: FTM's Avatar
    Sep 2004
