Middleburn ISIS BB- Mtbr.com
Results 1 to 7 of 7
    Reputation: DavidR1's Avatar
    Middleburn ISIS BB
    Which bottom bracket would you choose? I was all set on the Crank Brothers due to the 5 year warranty, but now I'm not so sure.
    I used the CrankBro Titanium ISIS BB before with the Middleburns, was happy with it.
    SKF bottom bracket. You can get them at MTBtandems.com.
    They're not cheap, they're not light, but they spin smooth for years with zero maintenance. I've got one with 3 years on it that I use with Middleburn cranks and it still feels like brand new.
    AZ
    AZ is offline
    Reputation: AZ's Avatar
    SKF , its the only one that I use now .
    Quote Originally Posted by steiny
    How heavy are they? Can't find a weight anywhere.
    Freezer
    Reputation: mlloyd007's Avatar
    Dec 2009
    200g actual weight. Got one from MTB Tandems, didn't like the ISIS design, returned everything for square taper and got a Phil Wood BB.
    Quote Originally Posted by DavidR1
    Go to the mtbtandems.com site, and scroll down about half way until you see SKF and then click on the "here" link. They use frames so I can't give you a direct link to the page.
    Weight is right around 300g for the BXC versions. The weights for the BFR are accurate (that's what I have) so I'll bet the others are accurate too.
