Results 1 to 2 of 2
    Probably drunk right now
    Reputation: Ken in KC's Avatar
    Manitou Fork for Geared FS Bike....
    Yep, you read that correctly. I'm looking for a Manitou fork for my 5-Spot and I'm looking for advice from you trendy, tragically unhip ssers for advice. A couple of things:
    - Has to be Manitou.
    - 130 mm
    Why post this on the SS board? Because the qualities I look for in a suspension fork are basically the same and they're based on SS riding. I currently have a Marzocchi Marathon SL on my SS that I like because I can adjust it until it's nearly rigid. It compresses when my bike's rider chooses a poor line or generally runs out of skill but is very, very stiff otherwise.
    The story:
    I have deal available to me for a Manitou fork. I don't know much about them. I would like to be able to either install this on my 5-Spot, on an older Fisher Hoo Koo (steel, Paul horz DO's, SS), have the fork interchange between the Spot and the Hoo Koo.
    So the questions:
    1, Which Manitou fork would be best for SSing? '
    2. Would I be better off keeping the Psylo on my 5-Spot and putting the Manitou on the Hoo Koo?
    3. Would I be better off putting the Psylo on the Hoo Koo and the Manitou on the 5-Spot?
    Ken
    Rollin' a fatty Moderator
    Reputation: DiRt DeViL's Avatar
    Ken,
    I'm no expert but ride Manitou's on all my MTBs and owned a GF hardtail some time ago.
    The Hoo Koo was not meant for a 130mm fork, so the Psylo with the travel adjustment may be a better fit for it. I ran a Kaitai with a Psylo SL without problems for about a year.
    I run a Black Super Air on my Unit and a Minute 3:00 on the FS geared, both forks are good but the Black is plusher. The Minute in my case is a better climbing fork due to the SPV valve, there's a Black with SPV so you could pick the one that suits you better.
    The Black travel could be lowered to 90mm so if you go that route may be a good fork for the Hoo Koo.
    My .02
