M952 vs Race Face turbine (square taper) cranks......- Mtbr.com
Results 1 to 12 of 12
    Curious.......
    Is either better suited for SS applications? I'm building a SS and a geared bike and trying to decide which would be better for either application. Since they both have a narrow profile I think "visually" they both flow better with the narrower tubes on a steel frame.
    Thoughts? Opinions? Experiences? Preferences?
    I should add that I do have a five bolt spider for the 952 cranks.
    "Just remember, all bikes have front suspension once you put your hands on the handlebars!" - 1SPD
    Karma Vampire
    Reputation: 29Again's Avatar
    Mar 2005
    Check with Homebrew Components
    http://www.homebrewedcomponents.com/...ess-chainrings
    for a spiderless single speed chainring using your Shimano cranks. That should save the "hassle" and weight of single speed chainring bolts, not to mention the spider.
    Ovaries on the Outside
    Reputation: umarth's Avatar
    I like Turbines from an aesthetic perspective.
    I'd do spiderless if I had a crank I wanted to do that with, especially if the chainring is from ISAR.
    one chain loop
    Reputation: fishcreek's Avatar
    i own both, and they are both pretty. like uMarty and 29 said, HBC spiderless is the way to go with the XTR or check the other thread about the titanium chainring. if they can copy a spiderless boone, that will be on my #1 list aesthetically.
    everything sucks but my vacuum cleaner.
    ballbuster
    Reputation: pimpbot's Avatar
    I love my XTRs with HBC spiderless. Great setup. Super narrow Q if you use the Ultegra double 109.5mm bottom bracket.
    <a href="https://picasaweb.google.com/lh/photo/DS7ux27OmvWr_oBBEBiwD9MTjNZETYmyPJy0liipFm0?feat=e mbedwebsite"><img src="https://lh3.googleusercontent.com/-MSRAfPH-h8E/Ti-CfXz-9yI/AAAAAAAAVyA/wt2xGZ46HXw/s800/IMG_1111.JPG" height="600" width="800" /></a>
    Remember that the chainring bolts are structural on RF Turbines. You need to install some bolts in the granny position even if there is no ring there.
    @ 29 / Fishcreek / Umarth / Pimpbot
    Thanks guys. The spiderless 952 option does seem to be the cleanest looking and I'm a true believer in fewer moving parts....then why am I building a geared bike too?!?! Unfortunately that gives me more ideas on how to spend money
    @ Pimpbot
    I would be running the the Turbines as a double so thanks for the education! I was completely unaware of that fact.
    NedwannaB
    Reputation: JMac47's Avatar
    Comparison?
    Quote Originally Posted by pimpbot View Post
    HBC's to the Spot and Jericho of old that I use to run? Had to switch to using a spider awhile ago when they wore out and would love to get 'less' again. Boone is not in my budget.
    As for narrower Q factor, I've had to use the Ultegra 118 bb to clear the chain stays using them on the VooDoo, which kinda negates that, but still is a great setup.
    Attached Thumbnails Attached Thumbnails M952 vs Race Face turbine (square taper) cranks......-full.jpg
    Wait whuuut, who did he tell you that!?!?....
    No known cure
    Reputation: Vader's Avatar
    I thought about going with a spiderless setup for the better half's bike, but (looks over shoulder) my cranks are five bolt.
    Ripping trails and tipping ales
    I believe spiderless will be the way to go. Now to decide between red and black. Hmmmmm......
    miwuksurfer
    Guest
    I've been running my turbines for about twelve years without granny bolts and they haven't exploded yet, but maybe I'm just lucky.
    NedwannaB
    JMac.....
    Don't think there is much of a comparison....
  1. What type of BB for Race Face Next LP cranks...square taper or octolink?
    By []D[][]v[][]D in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 11-04-2008, 11:17 PM
  2. Replies: 3
    Last Post: 03-04-2008, 11:48 AM
  3. Race Face Next Square Taper cranks...
    By Salt Cycles in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 11-18-2007, 10:29 AM
  4. Square taper BB/Race Face Next LP cranks a good/bad idea?
    By dawgcatching in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-16-2004, 06:57 PM
  5. Square taper BB/Race Face Next LP cranks a good/bad idea?
    Last Post: 04-14-2004, 02:23 PM
