Loud Drivetrain- Mtbr.com
Results 1 to 10 of 10
Thread: Loud Drivetrain
    Upset Loud Drivetrain
    I just installed a whole 1/8 drivetrain and it is much noisier than it was. Any one have any idea why? It has a KMC kool chain, gravity maximus cranks, velosolo 17t bolt on disc cog( so now its fixed), and a velosolo 32t chainring.
    Ride Responsibly
    Reputation: LWright's Avatar
    Chainline?
    Reputation: Mudflaps's Avatar
    Is it all 1/8", or 1/8" chain installed on 3/32" chainring/cogs? I'm unfamiliar with the brand name items you mention. The chainline issue raised by the second poster is certainly a valid question. Also, what was there earlier that was quieter?
    Quote Originally Posted by Mudflaps
    http://www.velosolo.co.uk/disccog.html
    http://www.velosolo.co.uk/vsmtbringano.html
    What was on it originally was the stock 3/32 chain/chainring/cog. Now it is all 1/8. And the chainline looks straight to me.
    Reputation: vindiggitydog's Avatar
    Your best bet is to follow the chain for a few. Are you using a bash guard?? Sometimes the chain will touch. Also it could just be the chain itself. If it has a tight joint it could cause some friction--noise. Hope you figure it out, because there is nothing more annoying than an SS with drivetrain noise!!
    I don't know if this might be it, but when I moved to a 1/8" drivetrain, the chain touched the crank arm ring tabs:
    I was running 32-16 & moved to 34-17 to resolve the issue.
    I shaved down the tabs and it still makes the noise. I think I'm going to get some of these :
    http://www.velosolo.co.uk/m5washer.html and see if it works. And no I don't have a bash guard.
    nothing to see here
    Reputation: Stevob's Avatar
    Have you lubed the chain yet?
    I see hills.
    I want to climb them.
    Stokeless Asshat
    Reputation: jeff's Avatar
    From the pic it appears you have some sag in chain but if not a tight chain will do it also.
    Zip ties? Not on my bike!
    Want:
    650B rims or wheel set. 80's vintage 32 or 36 x 135mm
    Yes I lubed the chain and the pic isn't mine.
