Lost of noise coming from rear...- Mtbr.com
Results 1 to 5 of 5
    you go ahead
    Feb 2005
    Hey I have a surly singleator held up in the push up mode with two zip ties, a SS sram chain, a kickass rear cog, and a surly chainring up front.. this setup is making some insane noise. (It almost sounds as if two metal cheese graters were being scraped together)
    Ive lubed the chain many times recently and the noise just keeps going. I do think it has to do with the chain though...Any solutions?
    CB2
    CB2 is offline
    Jam Econo
    Reputation: CB2's Avatar
    Is the chain 3/32 or 1/8? If it is 1/8 you need to switch the cage around on the tensioner to accommodate it.
    you go ahead
    Feb 2005
    Quote Originally Posted by CB2
    oooh you're right I forgot about doing that when i switched from 3/32 to 1/8
    that must be it.
    thanks
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by RustyBearings
    A change of diet may help
    mtbtires.com
    you go ahead
    Feb 2005
    Quote Originally Posted by shiggy
    must be it.
