Look for cheap effective chain tensioner for SS conversion- Mtbr.com
Results 1 to 11 of 11
    Reputation: JoePAz's Avatar
    May 2012
    Ok I have an old 26" bike with vertical drop outs and I am looking to do cheap single speed conversion. My thoughts now are a tension device like DMR.
    Saw this on Chain Reaction.
    DMR Simple Tension Seeker & Single Speed Kit | Chain Reaction Cycles
    Need a 17t cog rather than the 16t included. Is the DMR kit any good and single does it make sense to get the entire kit or just a seperate cog and use the lock ring from my old 9speed cassette. I plan on using a 9spd chain.
    Joe
    '18 Specialized Epic 29", Vassago Verhauen SS 29", '13 Santa Cruz Solo 27.5", XC, AM, blah blah blah.. I just ride.
    if you have an old rear derailleur around you can make one free. an short cage roadie derailleur would work best.
    http://forums.mtbr.com/singlespeed/a...ss-380459.html
    May 2015
    For cheap I make stuff myself ($0), for effective I make it work
    Reputation: Velobike's Avatar
    I've tried most of the tensioners. The best was the DMR.
    Using an old derailleur gives you the worst of both worlds.
    However I have't used a tensioner for several years, there may be better by now.
    A tensioner is good for trying out SS, but it's just another piece of equipment you can dispense with once you are committed to SS.
    I prefer to magic ratio a bike rather than use a tensioner. It keeps things simple - which is what you're aiming for with SS.
    Best of all is to get a proper SS frame - they are more likely to have the stiffer chainstays needed for singlespeeding, and that makes a huge difference on a climb.
    Latitude: 5736' Highlands, Scotland
    Oct 2015
    Really happy with my DMR.
    Nov 2014
    YESS was the best of the bunch I tried, but in all honesty they are all very much sub standard compared to a *proper* SS setup and kind of defeat the point of SS for me. What BB shell does your frame have? Although pricier a decent EBB may be a better bet if you plan to get in the this SS malarky
    Aug 2010
    DMR is solid. Not too terrible different from a "real" SS set up. It's quiet and can be set up to look halfway decent with the right cog/chain length. Still not as nice as sliders or EBB, but it will do. Definitely the best one I have used.
    Upcyclist
    Hows this for cheap: DIY Bicycle Chain Tensioner
    I've been lucky and found the magic gear on my last SS with vert drop outs, and my other two had horizontals. I've always wondered about how the Bionicon C Guide type work with SS.
    May 2012
    Installed the DMR kit and running a 17t cog. All is working well, but with the 16t the chain is too long and the two short with a full link removed. half-link time.
    Joe
    Quote Originally Posted by Velobike View Post
    Did you try the Gusset Bachelor? How did it compare to the DMR?
  1. Another cost effective 27.5" conversion
    By Cutbert in forum 27.5
    Last Post: 07-31-2014, 07:59 AM
  2. Cheap and effective protection
    By Nastygrindz37 in forum Apparel and Protection
    Last Post: 07-19-2013, 08:02 AM
  3. Great CHEAP chain tensioner for Bandit 26 and 29er!
    By swaneedawg in forum Transition Bikes
    Last Post: 06-14-2012, 12:44 AM
  4. Cheap Spoke Tensioner
    By pepelkod in forum Wheels and Tires
    Last Post: 05-25-2012, 07:20 PM
  5. Replies: 17
    Last Post: 05-18-2011, 09:04 AM
Members who have read this thread: 9
