lock ring tool for trail???- Mtbr.com
Results 1 to 17 of 17
    Reputation: babybabe's Avatar
    Dec 2017
    You guys who are prepared to swap cogs on the trail, what tools do you carry?
    Jan 2009
    How often would your change cogs mid-ride?
    If you feel the need for more than one cog, just put two cogs on your hub. That's almost a dinglespeed.
    It also depends on the hub you have. Some have a track-style lockring, which you could change with a Pedro's Trixie. No chain whip needed for that.
    Dec 2011
    Another option is the Gear Clamp GearClamp - Singlespeed Conversion Kit It requires a 2.5mm Allen wrench. I got a set for my SS to give it a shot, haven't ridden it yet though.
    Dec 2017
    Quote Originally Posted by mack_turtle View Post
    0-1 times per ride. For long rides, only when I tap out and need a bigger cog to get home. I realize different hubs require different tools. I have a Shimano-style free hub. I can get a lock ring with notches on the perimeter that the Trixie could grab onto.
    That clamp looks cool. I might be worried about scarring up the exposed free hub.
    Thanks for the input!
    Jan 2009
    just put two cogs on your hub. space them so he chainline is dead-center between the two cogs. carrying tools and taking your lock ring off in the middle of the ride would be a waste of time.
    Stein mini cassette lockring removal tool...
    Stein Tools for Hubs, Cassettes and Freewheels
    @adamalphabet
    Yeet so hard
    Reputation: tims5377's Avatar
    Oct 2010
    *obvious statement*
    Make sure your chain/tensioner system is long enough to accommodate both...
    Guerrilla Gravity BAMF
    Smash
    EAT MORE GRIME
    Reputation: 127.0.0.1's Avatar
    Nov 2013
    dooooood
    you need this. 2 speed, freewheel, kickshift
    Sturmey-Archer | S2 Black
    Gear 1 - 100% (Direct Drive)
    Gear 2 - 138% (Gear 1 + 38%)
    "Put your seatbelt back on or get out and sit in the middle of that circle of death." - Johnny Scoot
    Dec 2017
    Quote Originally Posted by 127.0.0.1 View Post
    dooooood
    Sold!
    Feb 2014
    I'd consider a Problem Solvers 6 bolt cog carrier. I've always been a bit dubious about the quality of their stuff but after getting their Zinger XD driver adapter, I was completely blown away at the quality of the product.
    Their 6 bolt would allow using their relatively cheap stamped cogs and would allow swapping without removing the lockring (just undo the 6 bolts).
    Jan 2009
    If you want just a small change, you can probably use one chainring and two cogs. If you want two drastically different gears, look into a dinglespeed setup.
    Oct 2016
    Quote Originally Posted by babybabe View Post
    A derailer
    Downcountry AF
    Oct 2013
    Umm it's a singlespeed, you should just plan on being in the wrong gear most of the time and grunt it out like the rest of us.
    Rigid SS 29er
    SS 29+
    Fat Lefty
    SS cyclocross
    Full Sus 29er (Yuck)
    Rent this space for $
    Reputation: Oh My Sack!'s Avatar
    Quote Originally Posted by Black Squirrel View Post
    A derailer
    Bwahahaha
    Don't go and derail the topic!
    SS Pusher Man
    Reputation: mtnbikej's Avatar
    Sep 2001
    How long of a ride are we talking about?
    I know I regularly do rides in the 60-90(8-10k') mile range, and have never thought about changing the cog for the ride home.
    It is part of riding the SS....you make a compromise your your gearing. Either make it too hard to climb, and have some top end later....or make it easier to climb, but spin on the flats later.
    For me and long rides....I generally gear my bike for later in the ride, which means I'll spin more early on, so I have some legs left at the end.
    Bicycles donít have motors or batteries.
    Ebikes are not bicycles
    Dec 2017
    Quote Originally Posted by mtnbikej View Post
    Thanks for the great advice. I figured the vast majority does not carry an emergency gear but was curious about what those that do use to swap the gears. In terms of distance, "long" rides of 50-60 miles to start, which is 4-6 hours for me around here, depending. At the time of the original post, I had zero SS mtb rides under my belt but plenty of geared rides (especially on the road) where I was tapped before the end of the ride. But after one SS ride most of my apprehensions have faded. Thanks for the thoughts and the suggestions! (Especially "derailleur"... )
    Reputation: coke's Avatar
    The only issue related to this that I've ever had was cramps so bad that I physically couldn't pedal up hill anymore. In those cases though, a slightly larger cog wouldn't have made a big enough difference.
  1. Golden Sun 7 speed lock ring tool
    By foxonabike in forum Tooltime
    Last Post: 02-24-2016, 06:50 PM
  2. Replies: 0
    Last Post: 12-24-2013, 10:00 AM
  3. The greatest lock ring tool?
    By customfab in forum Tooltime
    Last Post: 10-28-2012, 09:46 PM
  4. White Industries lock ring tool KNOCK-OFF?
    By upmtnsinbreck in forum Tooltime
    Last Post: 09-04-2012, 01:09 PM
