Kona Project 2 vs Surly 1x1 Fork- Mtbr.com
Results 1 to 11 of 11
    Reputation: Scott O's Avatar
    Any recommendations on the Kona Project 2 vs Surly 1x1 fork? Putting it on a 22" Surly 1x1. Thanks.
    you go ahead
    Feb 2005
    Ive never ridden the kona, but I ride the surly 1x1 and have no complaints. Plus it looks cool, which of course is the most important factor when deciding which fork to buy.
    blame me for missed rides
    Reputation: weather's Avatar
    i think the p2 is slightly shorter a2c. otherwise, i like the look of a straight blade fork.
    Reputation: seat_boy's Avatar
    They're almost the same length, Kona is 410mm vs. 413 for the Surly. I think the Kona is a bit lighter, and I like the appearance of the Kona quite a bit cheaper. Bikeman.com has them both.
    Eric
    Reputation: Strike the primer's Avatar
    The P2 flexxes way more.
    Get the Surly.
    Quote Originally Posted by Vulgar Display of Power
    Isn't that kind of the point with the P2? That it flexes enough to take the edge off?
    Apr 2005
    Quote Originally Posted by Scott O
    Can't say enough good things about my P2. That said, if you've got a Surly frame....
    Sorry this post probably hasn't helped at all :-)
    I've never noticed any objectionable flex in my Kona P2. Or any flex at all, for that matter. Then again, I'm light and don't do any big stunts or go for big air, I just ride.
    Comparing flex or ride comfort among rigid forks like this seems kind of silly to me... 3 psi of tire pressure would make more difference.
    Eric
    The Frank Zappa guy keeps staring at me. I think I must get the Surly. But the P2......
    Person
    I only got a few rides from my P2 before it cracked. Kona warranty can take a long, long time. I say go with Surly.
