    Kona Kilauea budget SS build
    Hey guys. I'm slowly building up the old frame that got me hooked on mountain biking, a '98 Kona Kilauea (Reynolds 631 steel). I'm trying to decide the cheapest way to convert it to SS. Performance has a Forte kit for $30, but I dunno if it's a better idea to get a spacer kit and go with the Surly Singleator or not. Thoughts?
    Attached Thumbnails Attached Thumbnails Kona Kilauea budget SS build-konakilaueass.jpg
    A Gentleman and a MTBR'
    As long as you're using a cassette hub as opposed to a thread on freewheel you'll have to get a spacer kit either way. The forte kit or the singulator are tensioners. You could measure your chainstays and use the magic gear calculator to check and see if any certain ratio might work without a tensioner. Good Luck! And that's quite the wiggly seatpost.
    Sweep the leg!
    Reputation: Caffeine Powered's Avatar
    Mar 2005
    My brother used a Frote kit for his SS build a few years ago and it's still going strong.
    Authorities speculate that speed may have been a factor. They are also holding gravity and inertia for questioning.
    The standard 32-16 singlespeed gear works with no tensioner (i.e. it's the "magic gear") on that frame. At least it does on my '97 Kilauea (Columbus tubing, same socket dropouts). However, I can't remember if I needed a half-link or not. Great bike. First post.
  1. My 2012 Karate Monkey Build - rigid, SS
    By thomasbien in forum Surly
    Last Post: 11-05-2012, 10:06 AM
  2. Fatback build project
    By DirtDad in forum Fat bikes
    Last Post: 05-18-2012, 01:01 PM
  3. 2011 Kona Hei Hei 29 FORK question
    By duggus in forum Kona
    Last Post: 01-17-2012, 11:20 AM
  4. Craigslist Kona Kikapu- How'd I do?
    By brdpkns in forum Kona
    Last Post: 01-16-2012, 02:43 PM
  5. Fork Recommendation for Carbon Tallboy Build?
    By Ace5high in forum 29er Bikes
    Last Post: 01-15-2012, 01:05 PM
