just an idea- Mtbr.com
Results 1 to 7 of 7
Thread: just an idea
    Reputation: dickeydoo's Avatar
    just an idea
    I got a singlespeed last year and have really loved it since i began riding it. i run a 32-13 gear combintation and have run into few problems with getting up hills but i was wondering, has anyone tried making a 1x3 or 1x2 i am fast with a singlespeed but i think that having those 2 other options might help me become faster.
    You will be scarred for life if you click my avatar
    Even the best riders will have trouble with most hills with the 13 cog. I would first try several different cogs. In PA with light hills I ride 32:16, moderate hills 32:18 and for heavy hills 32:20. Changeover time is about 10min even with the brake adjustment.
    For $3.98ea at Jenson you can experiment to find the right gear and then buy a more expensive cog, but these seem to work fine for me.
    "]http://www.jensonusa.com/store/product/CS407Z01 Dimension+Splined+Cog+For+Singlespeed.aspx[/URL]
    26FS & 29Rigid... best of both worlds
    Out spokin'
    Dec 1999
    Quote Originally Posted by dickeydoo
    This is completely possible. It's called "not a singlespeed."
    --Sparty
    disciplesofdirt.org
    Reputation: farrisw1's Avatar
    --Sparty
    ive tried other gear combinations and even with a 32 16 im spinning out on the hardest climbs, is there a way i could design a 2 or 3 speed?
    Just gear it so you have to walk the steepest hills.
    Or do this, but I don't care for it:
    http://www.whiteind.com/singlespeedg...reewheels.html
    Ovaries on the Outside
    Reputation: umarth's Avatar
    How are you spinning out on hard climbs?
    I like to believe there is a perfect ratio for every individual in every circumstance, even if I can think of several instances where this is not true.
