Results 1 to 12 of 12
    Art is Resistance
    Reputation: djcrb9's Avatar
    New question here. Jones Bar Questions
    I know this has been discussed to some degree, but i have a couple questions still.
    When switching from a reglular riser to an H-Bar, what have all of you done with your stems? Did you stay the same or go longer? I went from a 5 degree 105mm to a 15 degree 130, and i'm getting a lot of lower back pain. I don't know if i'm just not used to it, or what. Other than this issue, the bars are great, and i have no desire to switch back to the risers.
    Cold. Blue. Steel.
    Reputation: OneGearGuy's Avatar
    You may have over compensated a bit... So you didn't have any back pain before? Seems like you went a bit too long base on conversion comparisons on this board.
    My bike is setup around a 110mm, 0 degree rise stem (for use with a riser) and I am running a 130mm, 5 degree rise Thomson with my H-bars. Did you leave yourself enough steerer tube to raise the stem a bit? You may be happier with a 120 or 125mm stem to put you in the correct reach again- 105 to 130 is a pretty big jump...
    Just my .02ยข. OGG
    Spinning and Grinning...
    Art is Resistance
    That's what i was guessing... i'll cut it back a bit and see how that goes tonight.
    Thanks! (now if i only had every possible size of stem out there, i'd be set!)
    Recovering Weight Weenie
    Reputation: Padre's Avatar
    Hmmm..not sure I get the idea...can you post a larger picture of the bars in question?
    Bike Whore
    I went from a 110mm 6deg to a 130mm 6deg.
    It's different for everyone. I am guessing that maybe you went too long on your stem and as a result, you have to reach farther forward and this resulting in your back discomfort.
    Bikes not Bombs.....
    Reputation: SS Jerry's Avatar
    Stem swap out
    I went from a 110x5 degree stem to a 120x15 degree stem, fit perfect for me.
    JS
    Thanks to all of you for your friendships on this board..... -
    You Are What You Is
    Reputation: P-Funk's Avatar
    Check out Jeff's site for an adjustable stem that you can rent.
    Misfit Psycles
    Reputation: nogearshere's Avatar
    Mar 2005
    sorry for my ignorance...
    what is the url for his site? thanks.
    Expert of the Internet.
    BECAUSE I SAID SO
    You Are What You Is
    2:1 is offline
    Reputation: 2:1's Avatar
    another question RE shifters on H-Bar
    Jones' web site says the H-Bar is not so good with trigger shifters, but I'm not into the new slappy-happy STI stuff; does anyone have some feedback about how the bars work with regular rapidfire levers?
    2:1 is offline
    I'm fired...
    Totally stupid of me, asking gearie questions on the SS forum. Somebody should punch me.
    Here is some info/pics
    I modified some trigger shifters to work on my Gemini:
    http://forums.mtbr.com/showthread.ph...=rolling+stock
    Worked great in Moab/Fruita this year, just had to get used to the rapid rise shifting lol.
    http://red-haze.com/Pics.html
    Quote Originally Posted by 2:1
    red-haze
    The more I know the more I know I don't know.
    Let the bike ride the trail, you ride the bike.
    Look where you want to go, not where you don't want to go.
  1. bar, stem length and front shock questions
    By baraant in forum Beginner's Corner
    Last Post: 04-19-2005, 11:19 AM
  2. Jones bar - Anyone else NOT change stem length?
    By ATXSS in forum Singlespeed
    Last Post: 04-06-2005, 07:36 AM
  3. Jones H Bar question
    By beerman in forum Singlespeed
    Last Post: 03-05-2005, 02:51 PM
  4. questions about converting to a moustache bar..
    By green mt. boy in forum 29er Bikes
    Last Post: 01-04-2005, 04:43 PM
  5. Bar Ends -or- No Bar Ends
    By htims_nivek in forum Riding Passion and Stories
    Last Post: 03-22-2004, 10:15 AM
