I've bought a single speed frame!- Mtbr.com
Results 1 to 6 of 6
    Mar 2014
    I've gone and done it. I've bought one. I've wanted to for a long time.
    Amazingly it's nearly exactly the same, geo wise, as my geared hardtail.
    So I've bought a Cotic Simple. Steel frame, track ends. What do I need in terms of the rear axle, chain tugs etc. The rest is fine. I've got basically everything but slightly unsure of the set up at the rear end.
    Thanks folks.
    Ross
    Downcountry AF
    Oct 2013
    I'd use a 10x135 bolt on SS hub (like a Hope, or Surly, etc.) and probably a chain tug for good measure. good sturdy setup for track ends.
    Lots of info here.
    MTBR.com Single Speed Forum - Single Speed FAQ
    Rigid SS 29er
    SS 29+
    Fat Lefty
    SS cyclocross
    Full Sus 29er (Yuck)
    Reputation: thasingletrackmastah's Avatar
    When using the Hope bolt-on singlespeed hub, you can do without tugnuts.
    Just remember to carry a reel 8mm allen key, the 8mm bit on your multitool won't do the job.
    Belgian beer and Scotch whisky.
    Mar 2014
    Quote Originally Posted by thasingletrackmastah View Post
    For now I am going to be using my current geared wheelset with spacers and a surly cog. But I'm getting a new 10mm bolt thru axle for the rear wheel.
    Mar 2014
    So apparently it's really hard to find 10mmx135mm axle in the U.K. Superstar are out of stock. Everywhere seems to be out of stock of the DT Swiss version. Anyone got anything to sell?
    Mar 2011
    i use a hadley 10x135 thru bolt, is there a distributor in the uk?
  1. To 29 single speed or not to 29 single speed? My first post.
    By Citizen144 in forum General Discussion
    Last Post: 1 Day Ago, 06:07 PM
  2. chris king single cogs to build a cassette for hope trials evo 2 single speed hub
    By timsmcm in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-22-2014, 05:24 AM
  3. Replies: 0
    Last Post: 01-15-2014, 07:23 PM
  4. Project! 930 single track going single speed
    By Samblam in forum Singlespeed
    Last Post: 12-18-2013, 06:10 AM
  5. Replies: 6
    Last Post: 12-05-2013, 06:13 PM
