ISIS BB recommendation?- Mtbr.com
Results 1 to 8 of 8
    Back of the pack fat guy
    Finally, the OEM TruVativ ISIS BB from my SISS (that has since been moved to my 1x1) [email protected] out on me. I got significantly more life from it than I ever thought I would - probably close to 1200 miles? Anyway, I need a new BB, but it's been so long since I bought one, I don't know what's a good BB for SSing. I'm running a 180mm Stylo SS crankset on a Surly 1x1, and I go about 180 lbs, running 32x18 gearing. Weight is not an issue, but price is, so I'm currently considering either a Truvativ Gigapipe Team DH or a Truvativ Overdrive. Thoughts and opinions?
    Reputation: pswann's Avatar
    Earthpig:
    That is exactly my set-up. 180lbs, 180mm Stylos on a Surly 1x1 running 32x18. I like the FSA Platinum Pro a lot. Bikeman.com has them as part of their "Dirty 30" for something like $40. One thing to look out for though, is the tools needed for installation. The FSA needs the Park BBT-2 for 20 spline brackets, but I think the Truvativs use something different. If you already have the TV installation tool then you might not want to get another one just to switch brands.
    Reputation: mtnpat's Avatar
    FSA Platinum Pro
    I agree with pswann, that the FSA Platinum Pro is a good choice....I replaced my stock SISS BB with one about a year ago and it is still good - 32/18, 180lbs for setup.
    Also, if you remove the ringed washed from the splines (it just slides off), you can use a standard BB tool, like one for a square taper BB. Don't forget to put the washer back on before installing cranks.
    jrm
    jrm is offline
    Reputation: jrm's Avatar
    I'm about your same weight
    Using a gigabite Sl with out any problems.
    "Mr. Britannica"
    Reputation: roadiegonebad's Avatar
    lbs recommended this; has been fine so far (9 mos)
    sounds like a winner
    Quote Originally Posted by pswann
    Earthpig:
    Pswann - thanks for the info - do you remember what spindle length you bought?
    Whiskey Tango Foxtrot
    Reputation: eSSq's Avatar
    Quote Originally Posted by roadiegonebad
    Same here; same here.
    Quote Originally Posted by Earthpig
    No problem. I bought the 113mm spindle length and it works great. I removed the bash guard and am running the chainring on the "outside" side of the spider.
  1. Replies: 16
    Last Post: 06-13-2004, 10:52 PM
  2. Most durable ISIS BB....
    By Pigtire in forum Singlespeed
    Last Post: 04-30-2004, 07:49 AM
  3. Is anyone NOT having problems with their ISIS BB?
    By Backmarker in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-16-2004, 02:29 PM
  4. xtr vs isis BB spindle comparison
    By grutnip in forum Downhill - Freeride
    Last Post: 03-14-2004, 04:53 AM
  5. New Ultimate ISIS BB 145g with bolts, pics inside
    By Anders in forum Weight Weenies
    Last Post: 02-26-2004, 08:53 AM
