Results 1 to 28 of 28
    VENI VEDI BIKI
    Reputation: skankingbiker's Avatar
    Intermittent Chain "popping"
    The last few weeks I have been experiencing intermittent chain popping when under heavy load (i.e. big climbs). Only happens once or twice on a ride. I keep my chain clean and lubed. I checked for stiff links and found none. Chainline is spot on. Tension is good.
    Time for a new chain?
    Reputation: drMP's Avatar
    I too get it... Not sure why but I"m not using any master links (hard pinned). I am guessing it's from frame flex and the sides getting caught on tooth?
    SSOD
    Reputation: Crosstown Stew's Avatar
    Do either of you guys use a chain tensioner? I had this problem when I ran a surly tensioner. Mine was a combination of a link being mashed from cutting the chain, and too much chain. I took off the link that was mashed and put in a half link and that fixed it.
    Nope, SS specific ride (Spot). But i'll look for a buggered up chainlink.
    Let's ride
    Reputation: rensho's Avatar
    Can you guys define 'chain popping'? What exactly happens?
    What hubs or freewheels are you running?
    Hope SS hub, king bottom bracket and HBC rings
    Quote Originally Posted by drMP View Post
    That would be a TON of flex. I've experienced this, and the chain usually derails and sometimes takes the tip of a tooth or two with it. My frame ended up being cracked around the bottom bracket.
    What can happen though, is that frame flex causes chain tension to vary. You will notice the "popping" only tends to happen at the end the DS pedal stroke? That's where flex will change chain tension, leading to some slop, that will quickly be taken up, reulting in the "pop"... a REALLY smooth pedal stroke eliminates this, and I have NEVER had it happen on a fixed gear.
    I used to sometimes encounter this also at the bottom of a DS pedal stroke when doing something like a wheelie drop or pedal kick to lift the front. Strong pedal kick, and then a "pop" as the tension goes back in the chain as the NDS pedal comes around.
    Hope that helps. If its something different, I have no idea. I do know you don't really have to worry about this phenomenon described above as long as it is infrequent. If it starts happening all the time, look at chainline and have your frame checked for cracks.
    For me, riding bikes is not a hobby, it is a way of life.
    http://natureofmtness.blogspot.com
    Reputation: cbrossman's Avatar
    I get the same thing occasionally, and I keep everything clean and tidy.
    It seems to happen when I coast for a bit, usually because I need to catch my breath, and then on the next crank forward. Once or twice during a 2 hour ride.
    Craig, Durango CO
    "Lighten up PAL" ... King Cage
    fresh fish in stock...... SuperModerator
    Reputation: CHUM's Avatar
    i got a couple little 'pops' on yesterdays ride (a choppy 3 hours)....
    I9 hub, HBC rear cog (1/8"), and Middleburn front ring (1/8")....tension is good and alignment is spot on.
    i am, however, running a total POS PC-1 chain that I'm sure is fubar'd at this point.
    i'm gonna throw on a PC-7X to see if it happens again.
    Click Here for Forum Rules
    VENI VEDI BIKI
    I run Shimano XT hubs. The "popping" sound occurs at the bottom of the DS pedal stroke. it feels like the drivetrain is binding (kind of like when my chain tension on my fixie is too tight) and then "snaps" back into place. I have my tension set so that there is enough play even in the "tight" spot of the pedal rotation, so I do not think this is the issue. Don't recall seeing any frame cracks. Hope it is not my hub.
    trail rat
    Reputation: slocaus's Avatar
    "The physician heals, Nature makes well" - real fortune cookie
    CCCMB trail work for trail access - SLO, CA
    I get 'popping' under load when my chain is a little loose.
    My husband had this problem and found that the spider on his crank arm wasn't perfectly centered (he could measure the variation in spider bolt to crankset center between the bolt holes), so the chain would loosen then tighten every pedal stroke. He swapped cranksets and the second one wasn't as bad. Now he's on a mission to find the perfect SS crankset at a price he's willing to pay. Anyone got a Paul crankset for $100 ?
    trail rat
    Quote Originally Posted by miatagal96 View Post
    It probably does not exist.
    Manufacturing tolerances will vary with crank arm to BB, spider circle, chainrings, not to mention the rear hub, cassette or FW threading, and the cogs or FW itself. You would need custom made components to exceedingly high tolerances to achieve that, the mass manufacturing market of interchangeable parts is not going to accomplish that.
    Good luck on the under $100 part. Have him go find the Holy Grail, he will have better odds.
    Reputation: dtownmtb's Avatar
    Quote Originally Posted by CHUM View Post
    Here's a possibility
    Pull your hub apart and check the pawl springs. I chased down a sound like that for a long time. It sounded exactly like a drivetrain issue - chain specifically. Turned out a couple of pawl springs lost their spring. They were pushing a couple of the pawls only part way up. The pawls would partially engage until I cranked - then they would "pop" into place. You can sorta bend back the springs to give them their spring back - or get replacements from I-9.
    The core problem turned out to be an issue with the hub - which I9 took care of. Their customer service is fantastic. They worked with me through the long process of figuring this out and made everything right.
    Quote Originally Posted by dtownmtb View Post
    will check
    Let's ride
    will check
    While you're in there, I'd pull 3 of the 6 paws out with springs, and leave them out. It will change the sound, reduce drag(while coasting, which I warned you not to do ), and also get rid of this problem.
    The problem will also change/go away by itself as the paws and ring wear, but that will require riding.
    Quote Originally Posted by rensho View Post
    While you're in there, I'd pull 3 of the 6 paws out with springs, and leave them out...
    teamdicky did that...and was chastised by his mechanic.
    Reputation: UBUgoat's Avatar
    i've noticed mine does that once in a while, but seemingly only on the road (or maybe that helps me notice it)....does seem to be the downstroke....ride, pedal, coast, then that little <twank> slip <ching> sound.....then it's back to normal.
    Pretty much any single speed will eventually make this noise. Check your chain tension and chain line. Even with perfect alignment the amount of extra torque you're putting into the drivetrain can cause the ring/chain/cog to not line up perfectly and "pop". I've never experienced an issue with the popping outside of the actual noise.
    I work at Kona
    until i saw this post, i was concerned it was in the cranks/bottom bracket....pretty new bike, but still not sure.
    Reputation: SeaBass_'s Avatar
    Experienced this on my last ride and discovered my EBB had slipped from 9 o'clock to 8 o'clock and made my chain too tight so i was getting some binding under load.
    Jan 2011
    I had this problem a while back and discovered my chainring was loose... something else to check. Good luck!
    I noticed last night that one chainring bolt is missing! MAYBE that's my problem!! Probably have ridded 1000+ miles like that too?!
    Jan 2011
    Cool... bet thats it!
    trail rat
    Not only will that do it, but you are probably lucky, people who do not check their bikes carefully find the bolt missing when the chain ring folds / collapses with serious consequences!
    Thanks for posting this thread. I get this once in a while too. I often wonder about it, but finally got off my azz to come here and research it. Violet, here it is.....
    I hear and I forget. I see and I remember. I do and I understand. -- Confucius
    VENI VEDI BIKI
    As an update, existing chain was stretched.. Replaced chain and at same time, put on new cog in the back. No popping noises the last 4 rides.
    Just Ride
    Reputation: Cormac's Avatar
    Finally got my conversion kit and converted my 1x8 to SS. So I was already running a SS specific chain ring. Blackspire mono veloce or whatever it's called. Used the same chain as I never had a problem with it before. Just cut it down to fit. Then on the maiden voyage of my new SS rig I noticed a pop about once per steep climb. At first I thought maybe the chain was stretched but when I got home looked the bike over and found the tensioner had came loose a little. Tightened that up and hopefully that'll fix the problem? Or should I put a new chain on and be done with it? Also I noticed a growling sound coming from somewhere that I can't pinpoint. But everything turns just fine. Could it just be the chain rolling on the tensioner roller? This is the tensioner I'm using for reference:
    Sette Chain Tensioner at Price Point
    SS ==> Nut up or Shut up!
  1. RockShox Dart 3 problem "popping feeling"
    By MitchHonore in forum 29er Bikes
    Last Post: 04-23-2009, 11:44 AM
  2. Warning to my fellow racers: Beware of "Popping"
    By merlin in forum XC Racing and Training
    Last Post: 08-01-2008, 03:30 AM
  3. Need help with a popping "creak" sound
    By be350ka in forum Turner
    Last Post: 08-18-2006, 01:36 PM
  4. "popping" on SS, 1/8" chain?
    By xcgeek in forum Singlespeed
    Last Post: 09-20-2005, 07:40 AM
  5. Replies: 4
    Last Post: 03-02-2005, 05:46 PM
