Results 1 to 8 of 8
    Not helpful.
    Nov 2003
    I need help with chain tension, please.
    Sorry- I just don't feel like searching.
    I had the shop tighten my EBB, and now the chain is hecka tight. I mean tight.
    Is there such a thing as too tight? Seems like it's so tight that there's drag on the pedals when I spin 'em backwards.
    Yeah, I know- learn how to adjust it yourself. I know, I know.
    fp
    The man who fell to earth
    Reputation: Ziggy-Stardust's Avatar
    Learn how to adjust it yourself...y'know, y'know?
    Quote Originally Posted by Finch Platte
    Reputation: pacman's Avatar
    I wouldn't worry unless it put a drag on the cranks when you spin them. The pedals aren't affected by chain tension.
    When did you start riding SS?
    Complete Bastard
    Reputation: mward's Avatar
    That sounds way too tight, finch. Some BMX guys like to run their chains like that but I like mine so there's about 1/4" of slack in it. You gotta spin it to find the tightest point (chainrings are not concentric) and tighten it there so when the chain is at its highest tension there is a tiny amount of slack. Good luck.
    Retro Grouch
    Reputation: aka brad's Avatar
    Yes; and too tight is bad..
    fp
    Your chain should not be so tight that is binds in any position. Since crank spiders, chain rings and cogs are not perfectly round, you need to turn the crank arms as you tighten the chain to make sure is not too tight anywhere in the rotation of the chain ring. The result of a too tight chain is premature wear of the drive train and/or destruction of your bottom bracket and/or hub. EBB are very easy to adjust, tell us what kind you have and we'll help you.
    1G1G, Brad
    Reputation: Cygnus's Avatar
    too tight
    Maybe i'm wrong, but too tight seems to put unnecessary wear on bearings. i think i blew out a freewheel with a tight chain when i started SSing. same with a rear hub bearing. now i like to leave enough slack so that everything spins nicely.
    pewpewpew Moderator
    Reputation: Impy's Avatar
    i have to readjust my EBB like every 3 weeks or so as the chain stretches
    Not helpful.
    Nov 2003
    Thanks, all.
    I rode yesterday (S. Yuba) w/ Big Boulder, and his chain was as tight as mine, so I didn't let it bother me. Plus, he's learning how to adjust the EBB, so he can teach me later.
    Here he is, on his Cannondale 1FG- doesn't he look like he's having fun?
    For the feller who asked, I have a On-One Inbred that Jed built for me. It's pretty sweet, actually. It's a wee bit small, but doesn't seem to affect anything.
    Thanks again.
    fp
  1. Inconsistent chain tension?
    By Beckman4 in forum Singlespeed
    Last Post: 04-08-2005, 08:33 PM
  2. Good info on bike locks.
    By 2melow in forum General Discussion
    Last Post: 02-06-2005, 01:02 AM
  3. using MRP to tension chain
    By MD Bullit in forum Singlespeed
    Last Post: 01-19-2005, 08:25 PM
  4. Horizontal dropouts and chain tension questions
    By dirt_donkey in forum Singlespeed
    Last Post: 12-15-2004, 08:07 AM
  5. Adjusting chain tension - Bianchi SISS
    By AK47 in forum Singlespeed
    Last Post: 04-27-2004, 07:20 AM
