I made a Biopace looking ring- Mtbr.com
Results 1 to 11 of 11
    Reputation: badlander's Avatar
    Feb 2005
    Out of my Surly Stainless 32t - Yep, lost a chainring bolt going over a log pile. It sounded like a small rifle shot. I thought I had cracked a twig or something. Really no difference in the going until I started to go uphill and was mashing on the pedals when, yep again, the chain skips. Skips? I says to myself, and give everything a once over, not noticing the bolt missing. Everything looks ok, so I take off uphill and the chain comes completely off while mashing it. Ouch. I had just put on a Boone 20 t and was on a test drive. Luckily, there was a bail-out road back to my car and the chain would stay in place if lightly pedaled.
    So, my question is, does anyone use locktite on their chainbolts? I am thinking blue locktite. I have never lost a chainring bolt in my ill-advised, unglorious, debt-ridden life. And it sucks. I checked the bolts about 250 miles or so ago and they were good. New ring on order, the old one is deformed about a quarter of an inch, and it doesn't want to go round again. I believe I could weld up a jig and force it, but I would not trust it.
    Rick
    "Oh, and how dare you accuse me of lying, drinking, getting high" DessertRagged
    Bent is NEVER right again
    Got Mojo?
    Reputation: BikeMojo's Avatar
    Jan 2005
    Quote Originally Posted by badlander
    Yes.
    I use Red loctite. Like Brylcreem, "A little dab'll do ya."
    aLaN AT BikeMojo DOT com
    Quote Originally Posted by BikeMojo
    Yes.
    Personally, I'd go blue. Red may work, but blue is more appropriate for the job. No reason to use a higher strength than is necessary.
    Chris
    All 26.5" all the time!
    Reputation: Zanetti's Avatar
    Only grease on my chainring bolts.......never had a problem for over 20 years..... just check them every so often.
    Feb 2005
    Me too - Until Yesterday
    Quote Originally Posted by Zanetti
    There are 20 bolts on the bike, and the only loose ones were 2 chainring bolts. I don't know why. They are the only aluminum chainring bolts I have on any of my bikes. I have changed out chainrings many times and this is a first. I am going to do a dab of the red when the new ring gets in.
    Rick
    Out spokin'
    Dec 1999
    ... They are the only aluminum chainring bolts I have on any of my bikes...
    Have you considered sticking with steel bolts?
    ... I am going to do a dab of the red when the new ring gets in...
    It's your bike so you da man. But personally I would not go stronger than blue. There's a lot of surface area on chainring bolts. With red, I'd fear that they'd never come apart again.
    Good luck.
    --Sparty
    disciplesofdirt.org
    Got Mojo?
    Jan 2005
    Rick
    Red or blue.... I am not going to get into any heated discussions on it. I use ONE drop of red on the backside to hold the chainring 'nut' onto the ring. I have had no trouble removing them after using the red.
    I use this on my SS and my fixie. My geared ride I don't need it. I just check them every few rides.
    Reputation: shiggy's Avatar
    Dec 1998
    ...I use ONE drop of red on the backside to hold the chainring 'nut' onto the ring. I have had no trouble removing them after using the red..
    That is a heck of a lot different than using Loctite on the threads.
    mtbtires.com
    Aug 2005
    My experience...
    Singlespeed + steel bolts + blue loctite = no problems
    I've broken aluminum chain ring bolts and had both steel and aluminum come loose w/o loctite. I'm only 160 lbs.
    No problem changing rings with blue loctite on the threads.
    Reputation: Hardtails Are Better's Avatar
    May 2005
    Quote Originally Posted by shiggy
    Sure is. I'm with Sparticus. I wouldn't go stronger than blue. That's just me though.
