Hubs for Redline Monocog- Mtbr.com
Results 1 to 7 of 7
    Sep 2004
    I was thinking of building some new wheels for my Monocog, but the spacing is like 120mm Would it be that big of a deal to shove a 135mm hub in there? I was thinking of getting Mavic Crosslands and running them with regular tubes.
    Any comments on the subject
    JMH
    JMH is offline
    Sugary Exoskeleton
    Reputation: JMH's Avatar
    Feb 2005
    It's actually 110mm...
    ...and don't try it. You might be able to cram it in there, but you will end up breaking your frame.
    Any BMX hub will fit. King makes a nice one that costs megabucks, but there are dozens of alternatives. Check out Primo, their stuff is bling. Danscomp sells lots of cool BMX gear.
    JMH
    Mar 2005
    If it's steel it could fit
    Quote Originally Posted by Trevo
    If your monocog is a steel version it could fit, I've seen it done on a steel monocog, that a local bike shoper works at, the aluminum version would be a definate no go though. If you were worried about running a rear disc brake you don't need to be dismayed, Atom lab and
    DMR make an addapter which allowes the use of disc brakes on a bmx flip/flop wheel, it screws onto the non-drive side of the flip/flop, just make sure to get the right size, bmx hubs have a bigger and a smaller size, if you will be using a 16 or bigger FW get the small size, 14or 15t size freewheel get the bigger size
    Sep 2004
    Yeah, I'm going to toss one of those Mavic wheels in there when I work next. I think it should work, I could always cold set it a little.
    Just use a 110mm spaced BMX hub. Dan's Comp sells the Poverty BMX flipflop hubset for $45. Sealed bearings, great deal.
    pay me
    Reputation: Cole82's Avatar
    I had a local frame repair guy spreaad my steel mono and realing the dropouts. It works fine
    Sep 2004
    Yeah, I have the tools at both my shops.
  1. SC - are you listening? Scrap those DT Onyx hubs!
    By MTBmoose in forum Santa Cruz
    Last Post: 05-25-2005, 10:23 AM
  2. XTR or XT disc hubs???
    By staind in forum Wheels and Tires
    Last Post: 11-29-2004, 06:11 PM
  3. Any experience with Velocity hubs?
    By eman2 in forum Wheels and Tires
    Last Post: 10-07-2004, 01:24 PM
  4. Inexpensive weight wise hubs?
    By pimpbot in forum Weight Weenies
    Last Post: 08-25-2004, 09:18 PM
  5. Hope Hubs Disc vs. ONYX Hubs Disc
    By zaskar in forum Wheels and Tires
    Last Post: 06-25-2004, 10:05 AM
