HT angle question- Mtbr.com
Results 1 to 8 of 8
    Reputation: Cevan's Avatar
    HT angle question
    Looking to build a rigid/rigid SS. If a frame lists a HT angle of 69.5 degrees and shows the fork length as 500 mm, how much will it steepen if a 480mm rigid fork is used? In other words, is there some rule of thumb formula for how the head tube angle changes for say every 10 mm of fork length change?
    Reputation: Joe Handlebar's Avatar
    Apr 2016
    Rule of thumb? You betcha.... math! Specifically, geometry. Ok I kid, I kid. Assuming your both forks are being measured from axle to crown and have the same trail, your headtube angle will be about 70.5 degrees. Keep in mind that it doesn't just change HT angle. It will also lower your bottom bracket and steepen you seat tube angle as well. Roughly speaking, you will change your HT angle about 1/2 degree for each 10mm in A-C change.
    The member formerly known as Redtires....
    Thanks Joe. I'm not swapping out forks. The frame I'm looking at has a headtube angle of 69.5 and they assume a virtual for fork length of 500mm. The fork I am looking to pair with it has an actual length of 480 mm.
    Downcountry AF
    Oct 2013
    Quote Originally Posted by Cevan View Post
    for future reference: HTA is the more common way to write head tube angle. (HT angle to me reads "hard tail angle") also there's no such thing as a rigid/rigid SS, or a full rigid SS for that matter, it's redundant. it's just rigid SS. sorry, pet peeve.
    (someone correct me if i butchered the numbers) 500mm is the A-C which is for a 100mm travel fork if we're talking about 29ers. generally rigid forks are designed to account for sag on a sus fork. so a frame designed for a 100mm fork (490mm a-c) assuming 20% sag will most commonly be paired with a 480mm ish rigid fork. likewise, an 80mm sus fork commonly gets replaced by a 465-470mm rigid fork.
    there's no hard rules, you can choose a fork that preserves the HTA or steepens it a little which is common when swapping to a rigid fork. you can also fine tune with a different headset depending on how you want it set up.
    like Joe said, it's maybe 1/2 a degree different from a sagged sus fork. not enough to make a big difference. 480mm rigid fork is the correct length.
    Rigid SS 29er
    SS 29+
    Fat Lefty
    SS cyclocross
    Full Sus 29er (Yuck)
    Reputation: bikeny's Avatar
    Are you talking about a rigid fork or a suspension fork? I know you want to run it rigid, but is the geometry chart using a suspension fork or rigid? You have to be careful if it's suspension, as some list the angle with the fork at max length, and some with the fork at recommended sag.
    SSolo, on your left!
    All good info above, high school geometry has been much more useful than I ever thought it would be at the time.
    Quote Originally Posted by bikeny View Post
    Good to check, but I've always seen it as compensated for the suspension fork sag.
    Get off the couch and ride! :)
    Reputation: cmc4130's Avatar
    Quote Originally Posted by *OneSpeed* View Post
    . . . also there's no such thing as a rigid/rigid SS, or a full rigid SS for that matter, it's redundant. it's just rigid SS. sorry, pet peeve.
    heh heh. so what would you call a bike with a rear shock and rigid fork? besides KOOK?
    http://forums.mtbr.com/29er-bikes/re...id-682323.html
    Quote Originally Posted by Natedogz View Post
    The HTA is a static measurement, not a range (at least in my case) and it is assuming a 500mm A-C. So if I have a 480mm A-C, I am going to assume the HTA will be ~70.5.
  1. angle set question
    By cburden in forum Turner
    Last Post: 04-08-2016, 09:31 AM
  2. Head angle question
    By jazzanova in forum All Mountain
    Last Post: 07-09-2015, 11:38 PM
  3. stem angle question
    By stygz1 in forum General Discussion
    Last Post: 01-31-2014, 03:54 PM
  4. angle question
    By sponger in forum Videos and POV Cameras
    Last Post: 10-23-2011, 01:33 PM
  5. Age old question... New angle. WFO vs RIP?
    By subspd in forum 29er Bikes
    Last Post: 09-26-2011, 10:15 AM
