Is this how your ENO disc is setup?- Mtbr.com
Results 1 to 11 of 11
    Reputation: ernesto_from_Wisconsin's Avatar
    Just look at the picture. Some of you have sent me private messages with attachments with your mom's pictures - or your aunt (s).
    Here, take a look at this image. It will help you decipher how this is set up. Also works on non eccentric hubs.
    A la choy.
    Orange bike frame is my old Salsa Las Cruces cyclocross bike.
    Why do you have the cup/cone washers set up that way? Aren't they supposed to be set up above and below the caliper? Is there an advantage to this that I do not know about?
    Not trying to be a smart a$$, just curious if there is a reason for this.
    Super Moderator SuperModerator
    Reputation: driver bob's Avatar
    Quote Originally Posted by textbookonewk View Post
    x2. Those washers are set up wrong.
    Quote Originally Posted by driver bob View Post
    Clearance. That's why.
    Reputation: roadie scum's Avatar
    Jan 2011
    Nice! It has to be assembled improperly to make it work. No thanks.
    Frt Range, CO
    Reputation: pursuiter's Avatar
    How is it "improper"? AFAICS, that setup allows the caliper to rotate, it's just not exactly the way the factory sent them.
    May 2012
    What did you think of those pics of my mom, though?
    Quote Originally Posted by pursuiter View Post
    It is not proper, because Avid brakes are not meant to be mounted with all of the cup/cone washers under the caliper. If that is what it takes to get you riding then thats great, at least you are out on the trails. I am sure not going to buy a hub and disk brake adapter that I then have to improperly mount my brake caliper to. Surely this is not how White Industries meant for this to work.
    OP,
    Are you running a rotor that is one size larger than that disk brake adapter is meant for? If you reduced the rotor size, could you then mount the caliper correctly to the adapter?
    Frt Range, CO
    It is not proper, because Avid brakes are not meant to be mounted with all of the cup/cone washers under the caliper....
    It looks like it still works fine, full adjustment is possible when the caliper is mounted in either position. What bad result are you expecting?
    AZ
    AZ is offline
    Reputation: AZ's Avatar
    The CPS washers need to be mounted on opposite sides of the caliper ears for them to function as designed. There is no movement for misalignment the way they are mounted.
    Frt Range, CO
    OK, I see, you're right. OP, just get longer bolts and install some washers between the Eccentric Brake Adapter mount and the pivot washer set.
