How tight should an ENO cog be?- Mtbr.com
    SS Madness
    Reputation: xjohnnyx's Avatar
    I just installed a White Industries ENO 19t rear cog. My ACS Claw 20t spun off my Spot hub once I broke it loose. The Eno had to be wrenched on. I made sure I was not cross threading it. Is that normal?
    Medium?
    Reputation: Fast Eddy's Avatar
    It went all the way on though, right?
    If it went all the way on, it'll be ok. You're going to need a pretty serious lever to get it off though.
    King Pin
    Reputation: xrmattaz's Avatar
    Bonking ... not feelin' well
    Hopefully all will be ok.....???
    My ENO's thread on just as smoothly and easily as the ACS/Shimano's on me Surly hubs, no "wrenching" required 'til the last bit of snug up.
    Not a regular
    Probably just a case of a combination of very tight tolerances on the threading of your hub and the White f/w vs looser tolerances by ACS and others. Not everyone manufactures to the same tolerance.
  1. Replies: 2
    Last Post: 06-07-2004, 04:36 PM
  2. ENO flippity floppity
    By The Tree in forum Singlespeed
    Last Post: 04-30-2004, 04:44 AM
  3. cog dilemma...i need 21T maybe 20T cog. where??
    By Spookykinkajou in forum Singlespeed
    Last Post: 04-15-2004, 07:25 PM
  4. want to try fixed gear on my ENO......looking for cog
    By SS'r in Kansas in forum Singlespeed
    Last Post: 04-01-2004, 01:56 PM
  5. Freewheels: Shimano vs. ENO
    By Spudmeister in forum Singlespeed
    Last Post: 03-08-2004, 01:00 PM
