Results 1 to 12 of 12
    How much adjustment in a Paragon Slider?
    I wanted to know how much adjustment is in a Paragon Slider, AND how much is in one regular chain link???
    I'm wondering how long to have my chainstays built in reference to my current gear and bike.
    I currently use 36x24 gearing, with horizontal ends, and the axel appears to be 18" from the BB. So I'm looking to figure out how the sliders should be set up. I hope my question makes sense...
    Mark
    Slider has approx .75 inches of travel
    Mark
    Reputation: bulldognz's Avatar
    What Bikes are using the paragon slider? I have been looking to build a SS but the one requirement I have is it must have paragon sliders.
    Maro1
    Mark
    Quote Originally Posted by bulldognz
    Maro1
    Dunno... my slider is loose as my hausgemacht frame will use it
    Mark
    Old, stale, negative
    Reputation: bstrick's Avatar
    Not sure I get it but here's what I have...2005 V00D00 Dambala 9er. I have the ability to run a 34 x 18/24. It is about as far as you can get when looking for spread between gears with a slider system. The chain is a PC-1.
    I'm thinking of getting a custom frame with the Paragon sliders... How long is one complete link of a PC-58 type chain?
    Reputation: pacman's Avatar
    Quote Originally Posted by Wish I Were Riding
    All bike chains have 1" links. A slider or EBB with 1/2' of adjustment will handle any gear combination without the need for a half-link.
    Quote Originally Posted by pacman
    So if I currently have 18" stays with my gear, and I remove 1 link, then I would have 17" stays (if its possible)?
    If so, I would probably have the builder make it so the paragons adjustment start around 16.75"? Someone else said they have .75" of range right?
    local trails rider
    Reputation: perttime's Avatar
    Aug 2005
    So if I currently have 18" stays with my gear, and I remove 1 link, then I would have 17" stays?
    17.5", by my math: the chain does not go just one way: it comes back too.
    Quote Originally Posted by perttime
    Oh okay, good point.
    Is there a gear calculator or something that shows chainstay length for given gear combos?
    Like if I have 17.5 for 36x24, how long will it need to be for 36x23?
    36x24 CS = 16.973 or 17.474 or 17.975
    36x23 CS = 17.094 or 17.595 or 18.095
    Give a 1/2" of adjustment you can use any gearing.
