how many spacers?- Mtbr.com
Results 1 to 8 of 8
    SS conversion question. how many spacers?
    ok, this is probably a dumb question... if it is, i expect a dumb answer
    i'm in the process of converting my P3 that i use for DJing/Urban. i've pretty much got it all set up already using a surly singleator. i do, however still have the SRAM 9-speed cassette on it fully assembled. my last step is to take that cassette off and only keep the 16t and fill the rest with spacers. one of my LBS's was kind enough to sell me 4 plastic (4.5mm?) spacers for $1. i called another LBS and they have some they can sell me as well (although they want $3.99/each for them?).
    how many spacers do you typically need? just a rough estimate. i'm guessing one for each cog you remove?
    thanks in advance.
    Reputation: pacman's Avatar
    Roughly speaking 1 3/4 spacer for each cog. One for the spacer that was in the cassette and 3/4 of a spacer for the cog itself.
    formerly Gobike69
    Reputation: Big Daddio's Avatar
    Cog
    I'd ditch the SRAM cog and throw down 5 bucks for a Shimano DX cog. They're cheap and there's less chance of chain skip.
    Derailleurs owned: 0
    Reputation: c0jones's Avatar
    "surly singleator"? doesn't a P.3 have horizontal dropouts like my P.1?
    Chris Jones
    Quote Originally Posted by c0jones
    Chris Jones
    i wish. my P3 is the green model from 2001... before they started making the single-speed/street/whatever ya call it horizontal dropout frames. it has "semi-vertical" dropout, thus the need for the tensioner.
    anyways, thanks for all the input... picked up about 8 spacers from a few LBSs and managed to find the right combination to get it all set up. rides very nice.
    gonna stick with the SRAM cassette for now... never had any issues with it and i'm kind of an anti-shi(t)mano type of guy
    Reputation: scottms33's Avatar
    ummm ?
    i guess you need to look at your chain line to see what you might need, here is a pic of mine, the gray ones i got on ebay with 2 other ones and a cog for 9 bucks, and the 2 black ones i got from the lbs for .50 cents.
    scott
    After breaking open old cassettes I built up this.
    Rollin' a fatty Moderator
    Reputation: DiRt DeViL's Avatar
    Get a piece if 1.25 pvc schedule 40 tube and cut as needed.
  1. boone spacers for my rear hub
    By Spookykinkajou in forum Singlespeed
    Last Post: 08-18-2004, 12:37 PM
  2. Whats the max amount of spacers I can use?
    By Boj in forum Shocks and Suspension
    Last Post: 05-15-2004, 07:57 AM
  3. How many spacers is too many?
    By Yellowstone Yeti in forum General Discussion
    Last Post: 05-10-2004, 07:15 PM
  4. BB Shell Width - When to use spacers
    By dragonej in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-07-2004, 07:57 AM
  5. carbon fiber spacers...
    By sodade in forum Weight Weenies
    Last Post: 03-06-2004, 01:32 PM
