"how to" help needed- Mtbr.com
Results 1 to 6 of 6
    The Notorious S.L.O
    Reputation: btadlock's Avatar
    I have a Raliegh Chill that I wish to convert to a SS, with no idea how/where to start.
    anyone know of a good how to thread or site that I should start with?
    Thanks.
    BT
    11 Trek Hifi Delux 23in
    05 Giant NRS 22.5in
    Evergreen Co.
    "All I need is.......two wheels and the truth."
    Did you not see the FAQ stickied at the top of the page?
    one chain loop
    Reputation: fishcreek's Avatar
    ^+1
    read this FAQ, should be straight forward.
    MTBR.com Single Speed Forum - Single Speed FAQ
    remove all shifters and derailleurs.
    remove cassette and replace with a preferred SS cog and spacers.
    remove all chainrings and replace with the preferred chainring size. get a shorter chainring bolts or shim the existing one with washers.
    buy a new chain. match the chain width (3/32 or 1/8) depending on your chainring/cog width.
    find a way to tension the chain. there are lots of chain tensioner available in the market, either spring tensioned or rigid.
    if you have a 1993 Technium Chill, the magic gear is 32:17.
    everything sucks but my vacuum cleaner.
    one chain loop
    AZ
    AZ is offline
    Reputation: AZ's Avatar
    And don't forget to post pics.
    You also have a few online retailers that you can buy the single speed conversion kits. Or your local bike shop may be better suited to help you as well.
