How big a tire fit's in a Kona Unit frame ?- Mtbr.com
Results 1 to 6 of 6
    Rear tire that is. Thanks
    semi-evolved simian
    Reputation: Mine'sAPint's Avatar
    Quote Originally Posted by Rockdogger
    '04 or earlier ? I can fit a Geax Blade 2.25 in the back of my '04, that's a pretty big tire and there's ample clearance for it. That tire won't however fit in the back of my friend's '03... the chainstays on the '04 are spread at least 10mm wider in order for there to be space for the cool sliding dropouts.
    SS Grrrrrrrl
    Reputation: dirtcrab's Avatar
    2.35 on '04 frame
    I briefly had a Schwalbe Fast Fred 2.35 on my '04 Unit. No clearance issues with this tire. I didn't actually measure the tire to see if it was actually 2.35, but it looked pretty fat!
    Reputation: (Tom)'s Avatar
    2.25 blade on the 03
    They fit on my 03 frame fine. The wheel was about 1/2 back in the horz. drop out..
    Later
    Fight the Kakistocracy!
    Reputation: veelz's Avatar
    Huge Geax Sturdy 2.25, no problem
    I can fit a Geax 2.25 Sturdy with the dropouts all the way forward on my '04 ExploSSif, which is the same as the Unit in '04. See for yourself. The Sturdy in the 2.25 is almost like a 2.5, much bigger than the Blade that Ian (Mine'sAPint) is running.
    veelz
    Gravity, not just a good idea, it's a law.
    The only one consistently and constantly applied, no exceptions.
    semi-evolved simian
    Quote Originally Posted by veelz
    Bigger than the Blade ? SWEEET!!! Now I wanna try one!
  1. Blur rear tire choice thread from old boards
    By CraigH in forum Santa Cruz
    Last Post: 03-03-2004, 05:16 PM
  2. Kona Unit in stock?
    By leeco in forum Singlespeed
    Last Post: 03-03-2004, 01:34 PM
  3. 04 Kona Unit or Bianchi SASS
    By Poothooter in forum Singlespeed
    Last Post: 03-02-2004, 11:24 AM
  4. kona stinky dee-lux frame geometry
    By your name here in forum Downhill - Freeride
    Last Post: 03-01-2004, 06:30 PM
  5. Advice with Stan no tubes sealent ?
    By Johny Rotten in forum Singlespeed
    Last Post: 02-13-2004, 03:39 PM
