Hope SS Hub, bolt sizes?- Mtbr.com
Results 1 to 20 of 20
    It's carbon dontcha know.
    Reputation: 6thElement's Avatar
    Thinking about getting a wheel built up using the Hope SS hub, is it an 8mm hex on the 10mm bolts?
    Can they be tightened independently, so if I need to take the wheel off on the trail I only need a single 8mm?
    I just built up a set of SS wheels with the Hope Pro SS hub. The stainless bolts that came with it use a 6MM hex wrench. The hub uses two separate bolts, so only one wrench is required to take the wheel off. I upgraded to Ti bolt from racebolts.com for about $20 bucks.
    Hope you like a very loud ratcheting hub, the Hope are loud and I love it.
    i don't give a shift
    Reputation: collideous's Avatar
    Did the same an upgraded to Ti bolts as well. Added a custom washer designed for the bolts I purchased. The stock bolts just look cheap.
    local trails rider
    Reputation: perttime's Avatar
    Aug 2005
    The stock bolts fit my color scheme just fine
    No problems removing and installing the wheel with one multi tool.
    Reputation: Brewtality's Avatar
    Quote Originally Posted by perttime
    Give it time. Yours will take a dump soon enough
    I had to remove one with vicegrips last night. Good thing it was in my garage and not on the trail. Ti bolts are on order for me.
    Its all Shits and Giggles until somebody Giggles and Shits
    Upgrading the bolts
    The nice thing about the new Ti bolts is the hex wrench size goes from 6mm to 8mm. This allows for easier torquing. I don't run a chain tensioner on my Gary Fisher Superfly SS, and I like the much larger bolt for tightening. Have had no problem with slipping.
    Quote Originally Posted by zieglebeet
    I've already got a couple of geared Hope wheelsets, I love the loud hub.
    Thanks for the answers people.
    "Give it time. Yours will take a dump soon enough
    I had to remove one with vicegrips last night. Good thing it was in my garage and not on the trail. Ti bolts are on order for me."
    Pff if you use good tools and use your tools good it almost impossible to destroy bolts. I do not mean to infringe on your skills in the shed but allen heads do not need to be destroyed. But good tool sizing is absolutely necessary as much as cleaning the bolt head before using the tool.
    Aug 2005
    Can you help out with a link to the part? Thanks.
    Racebolts Ti bolts for Hope Pro SS hubs:
    http://www.racebolts.com/index.php?m...d3df83d6565bda
    They are the 10mm x 35mm with a 1.5mm thread pitch.
    Quote Originally Posted by DiDaDunlop
    No need to preach to me about tool useage and quality. I work for a major industrial engine distributor, troubleshooting and repairing industrial engines of all sizes, from 3.0L to 60L. My tool inventory costs more than most houses. Building bikes is childs play for me.
    Fact of the matter is, the Hope hub bolts are made out of stainless steel. Stainless steel is too soft of a material for use in anything but decorative bolts.
    My Hope hub bolts were never touched with anything except Snap On Allen wrenches. From the first time I torqued them up, I could tell they were soft bolts and the Allen sockets immediately started deforming.
    I also found that the Allen sockets in the bolts are not sized properly. They are 'supposed' to be a 6mm Allen socket. Bu the socket is slightly bigger, just enough that any 6mm Allen is going to be loose. But no fractional Allen wrench will fit. The sockets are also too shallow. They need to be another millimeter deeper to ensure proper engagement of the Allen wrench.
    No matter what, the Hope hub bolts are worthless and a Ti upgrade should be factored in whenever ordering these hubs.
    Reputation: Tanin's Avatar
    Quote Originally Posted by collideous
    Looks sharp ! Where did you get that washer?
    I am sorry that I have offended you. I only wanted to say that allen keys need to be used carefully.
    Also I have two HOPE SS hubs wich both see regular use. I do not have any problems with the bolts. They stand up fine to regular removing and fastening. I need to mention that they are in vertical drops (I use EBB's) so they may not be as tightened as on track ends or the like.
    Quote Originally Posted by Tanin
    Made a quick drawing, had it made and anodized.
    You didn't happen to order 2 extra washers to sell to a random MTBR member that can't draw as quick as you?
    No, unfortunately I have no extra washers.
    (slight return)
    Reputation: slide mon's Avatar
    Those Ti bolts look pretty good. I posted some info on hope bolts last year after stripping mine:
    Hope Pro II singlespeed hub bolts
    -slide
    Reputation: nspace's Avatar
    Never had problems with the stock 6mm steel bolts myself. They aren't fancy but I wouldn't say they look cheap. They do the job. Unless you need the added clamping force from a bolt-on hub for horizontal dropouts, and you want quicker wheel changes, there is a quick release conversion kit that is also available. I have converted mine, and it was just a matter of removing the end-caps.
    Expert Crasher
    Reputation: GreenLightGo's Avatar
    Quote Originally Posted by rsquared28
    I agree with you. I've had two sets of rear bolt on hubs. First set, never had an issue but one was beginning to slip. Second set - soft from the start. This using a Park tools multi-tool.
    I went to Home Depot and got some grade 8 bolts. 17mm head I think (box end wrench). Works well enough. Nothing fancy but easy to fix.
    Happiness depends more on the inward disposition of mind than on outward circumstances. Benjamin Franklin
    What torque setting are you guys using on the ti bolts? I just got my hub and I'm using 20nm on the stainless ones.
    Rigid bikes FTW!
