Hope Pro 2 Evo- Mtbr.com
Results 1 to 17 of 17
Thread: Hope Pro 2 Evo
    Aug 2010
    Hope Pro 2 Evo
    Looking to order a rear....
    1. Anyplace sell with steel free hub body?
    2. Anyplace sell with Bolt on axle option?
    3. Anyplace sell bolt on axle separately? Jenson only sells for non-evo version.
    Reputation: LyNx's Avatar
    ASSuming that since you're asking in the SS forum you're intended use is on a SS, so what you're looking for is not the Pro2 EVO, it's the Pro2 EVO SS/Trials hub which comes with a steel freehub body, bolt on axle setup and abbreviated freehub body. Hope Pro 2 Evo Rear Hub - Single Speed-Trials | Chain Reaction Cycles
    Aug 2010
    Hope Pro 2 Evo
    Actually I'm looking for the the standard cassette hub. I've bought a few others and was able to spec the steel free hub.
    It will be for SS.
    Oh, well then you'll have to look around or look to buy the hub and then parts needed to convert to what you want, can't say I've seen the configuration you're looking for readily available while browsing.
    Quote Originally Posted by racefit View Post
    It will be for SS.
    Aug 2010
    That's the weird thing. I've ordered multiple Hopes from LBS and just asked for stainless hub and it was no big deal. However when looking online it's a big mystery.
    I gotta ask, why would you not want the single speed trials hub if it is for single speed? Unless you are going to also use it on another bike.
    Aug 2010
    Quote Originally Posted by timsmcm View Post
    With the geared version you get more space to adjust chainline. And although most of my bikes are SS, it's an added bonus to be able to run gears if needed. Better for resale too. The only advantage the Trials has is higher engagement and IMO that's negligible.
    Why in the hell do people always think about resale?
    Buy the best product that suits your needs, then if by some chance you have used it enough or want something different, then try and sell it if you want, but don't compromise the purchase for resale.
    You CAN run gears on an SS/Trials hub, I did it for over 7 years so I had a dishless and stronger wheel (that is the real difference between the SS/Trials and normal hubs), it worked fantastic and lots of others have done this as well.
    http://forums.mtbr.com/singlespeed/a...ub-456304.html
    http://forums.mtbr.com/29er-bikes/6-...up-573783.html
    Oh and what do you mean you get more space to adjust chainline, how frikin far would you want your chainline moved that as SS/short freehub wouldn't accommodate??
    Wanna ride bikes?
    Oct 2013
    ^ this!
    Single speeding is what the SS/trials hub is designed to do. it builds a stronger wheel, and has more than enough adjustability for chainline. plus you get the steel freehub, and bolt on package in one. should you choose to sell it later, you should have no trouble selling it. there will always be a demand for high quality products.
    yes you can do it with a standard hub, but not as good IMO.
    Rigid SS 29er
    SS 29+
    Fat Lefty
    SS cyclocross
    Full Sus 29er (Yuck)
    Aug 2010
    I'm not looking to belabor a debate that has been hashed many times over.
    Just looking for answers to my original question.
    I agree 100 %
    SCRUBDUNKER
    Reputation: razardica's Avatar
    It's not a debate, you're ****in' wrong is all.
    Aug 2010
    I prefer the geared version. Looking where to get it.
    Wanna ride bikes?
    Oct 2013
    any euro website
    Rigid SS 29er
    SS 29+
    Fat Lefty
    SS cyclocross
    Reputation: dbhammercycle's Avatar
    I've not seen it online in the configuration you would like. It is my assumption that you would need to order the steel freehub separately, but you may be able to find a thru axle version. You should order through your LBS if it hasn't been a problem in the past or possibly go through Hope directly?
    That said, I agree with the other fellas above, get the trials SS version. However, if you want one wheelset for several bikes ok, but realize that you're on the couch if something snaps.
    I don't know why,... it's just MUSS easier to pedal than the other ones.
    Bored
    Reputation: bigwheelboy_490's Avatar
    Jan 2003
    I was able to get mine with the alloy freehub body from Chain Reaction with the 10mm bolt through axle.
    Using a wide body cog, no gouging on the freehub body.
    MTBR is serious stuff.
    You never get better until you get out of your comfort zone.
    Hairshirt Rider
    Reputation: Loudpawlz's Avatar
    Maybe give Monk a Moo a call and see if they can get you what you want. I've also order directly from Hope Tech USA when I need small parts or conversion kits.
  1. Hope single speed hub or hope standard hub?
    By dcurtis in forum Singlespeed
    Last Post: 05-20-2013, 12:34 AM
  2. Replies: 3
    Last Post: 03-27-2013, 07:10 PM
  3. Replies: 18
    Last Post: 01-12-2013, 08:59 PM
  4. Hope Saw 203mm Floating Rotors / Hope Mono M4
    By Deer_Dodger in forum Brake Time
    Last Post: 05-16-2012, 05:34 PM
  5. Replies: 8
    Last Post: 03-13-2011, 10:54 PM
