Homebrewed ring direct mount on xo crank?- Mtbr.com
Results 1 to 5 of 5
    May 2005
    Anyone pulled the spider off of an XO crank and did a direct mount of a Homebrewed Component ring?
    Thanks.
    Really I am that slow
    Reputation: SlowerThenSnot's Avatar
    Quote Originally Posted by jfriedly View Post
    Thanks.
    all the sram X7,X9,XO cranks should work with the spiderless HBC ring
    Read my BLOG!
    just a guy who loves bikes and exploring
    Spear & Magic Helmet
    Reputation: JohnGray's Avatar
    Thanks.
    I added a spiderless ring to my Bontrager cranks that (according to Dan) uses the same spider as the Truvativ cranks. A well done ring. Keep in mind that it is flat, not dished like the spider. I've only had one really good ride and it disappeared - in a good way. No problems. Very smooth. Never thought about the fact that it was a new ring until the ride was over. Pictures here:
    http://forums.mtbr.com/showpost.php?...postcount=1019
    John
    p.s. If your spider is a double ring set up and you want to get rid of it shoot me a PM.
    Oct 2007
    I just mounted one up to an X9 crank and have about 3 hours of riding on it with a 1x10 setup. 10 speed chain was just ever so slightly tight when i first had it on but has broken in nicely. no complaints flawless operation so far. the swap is really easy too, all you need is a T25 torx.
    The need for singlespeed
    Reputation: zaskaranddriver's Avatar
    ^^I've been thinking about trying that setup--got any pics?
  1. Direct Mount XT to SRAM XX Mount
    By rockyuphill in forum Rocky Mountain
    Last Post: 09-27-2014, 11:30 PM
  2. XTR direct mount to IS
    By Mr Pink57 in forum Brake Time
    Last Post: 10-24-2010, 05:03 PM
  3. XTR Direct Mount FD
    By Hawgzilla in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-14-2010, 06:48 PM
  4. Looking for direct mount
    By tannerdrummer in forum Arizona
    Last Post: 12-26-2009, 10:40 PM
  5. Replace Triple-Ring Crank with Single-Ring Crank?
    By pikminotaur in forum Singlespeed
    Last Post: 09-13-2006, 05:03 PM
