Homebrewed Components Alternative- Mtbr.com
Page 1 of 2 12 LastLast
Results 1 to 200 of 301
    mnoutain bkie rdier
    Reputation: rydbyk's Avatar
    Bring 'em on!!
    The MRP spiderless looks nice to me. A buddy just got one and loves it..
    No..I don't work for MRP..
    Multiple colorways soon too..
    Master Gardener
    Reputation: Velokid1's Avatar
    May 2005
    I need one for some X9 cranks... where do we order them?
    And do they have 34T yet?
    Link please? I need one for SRAM AKA cranks in 32t.
    mnoutain bkie rdier
    Pro Bike Supply among others... Apparently they are making a ton of them to send to suppliers soon...heard thru the grapevine
    Not sure about the 34t, but I am sure if there is a demand for it, they will make it..
    Give them a call..
    mnoutain bkie rdier
    Quote Originally Posted by SS Hack View Post
    MRP BLING RING Direct Mount Chainring - Pro Bike Supply
    search MRP Bling Ring
    Master Gardener
    May 2005
    Ah, great. Thanks for the heads-up.
    I wonder if QBP or BTI are stocking any. Any idea?
    Does the price seem really high? Are they made in the USA?
    Mar 2012
    Todd at Black Cat was selling these RCR direct-mount chainrings about a year or so ago. Not sure if they are still available or not...
    Disclaimer: I've never used one of these ring so I can't vouch for them. They look nice though.
    Master Gardener
    May 2005
    I have an order in for a B Cat as we speak, so that would be convenient. Thanks for the info.
    That's awesome if all you ever want to use is sram...
    Master Gardener
    May 2005
    Yep, it is.
    Reputation: Nubster's Avatar
    Quote Originally Posted by rydbyk View Post
    .Multiple colorways soon too..
    Any more info on this? I was going to order a Bling Ring soon, but if they have colors coming out soon, I'll wait.
    Super snowflake = when an avatar offends you so much you have to cry about it and report it to admin. Life must suck for you.
    Reputation: Ooklathemok's Avatar
    Dec 2011
    Renthal also makes rings, although no spiderless.
    Low Rep Count
    Reputation: 1SPD's Avatar
    Well, I know folks have used Boone and Blackspire in the past with good success though I have never really seen places to order either of them. You can also look into Rotor Q as they also have an SS ring though it is an elliptical shape.
    If you have a M960 crank you are very limited however due to the odd 102 bcd but I believe Blackspire makes one that fits. (unfortunately, this is what I have so the HBC is the best option at the moment as far as an SS ring goes-not because of customer service)
    Low Rep Count
    Surly also makes SS rings and I suspect you can get rings from Truvative as well (I mean they put them on the Stylo cranks right)
    djrez4
    Reputation: djrez4's Avatar
    Quote Originally Posted by djrez4 View Post
    I would have a little trouble fitting those on spiderless crank arms. Duct tape and bubble gum maybe?
    Low Rep Count
    Probably however, the OP didn't state that he wanted to only see spiderless alternatives.
    Anyone know what the chainring (non-spiderless) size needed for the SRAM S1400 crankset? I know it's a 4 bolt. I'd like to look into the Salsa rings as a possible holdover for an HBC if I don't go with an MRP, especially since the Salsa comes in red.
    Low Rep Count
    Yep, I would have been all over the Salsa's myself but the M960 while a great cranks, has a stupid frickn bcd size! While it might be available in black or silver, it is only available in red in the 104 bcd.
    Mar 2011
    There's a big thread in the drivetrain forum about the bling rings. Apparently there's some issue with the first batch being out of round. I figure that would be a problem with SSers
    Low Rep Count
    I know it would be for me (SSr) as you end up with tight/loose spots. They say it is minute but you can still see it when you rotate the pedals, at least that has been my experience anyway. I actually have a little bit of that going on right now with my HBC ring and Surly combo. I thought maybe it was the new Surly cog that I have so I slapped my White Industries set up back on and still have the issue.
    One thing you can do is mark how you mount it when you first put it on. If you have a tight spot, you can try to take it off and rotate it to see if that helps even things out. I have heard that it can also be the actual bolt locations on the crank as well. None the less, I have been doing fine with it but I certainly would not want to buy one knowing that this is an issue.
    Quote Originally Posted by irv_usc View Post
    That's why they were selling them at a discount and there was a disclaimer on the MRP site stating the rings were out of round and that they could possibly be an issue for SS'ers but not so much for geared bikes.
    Master Gardener
    May 2005
    I heard about the MRP problems from a friend yesterday. He's running an MRP and just ordered a new RCR ring today.
    By the way, if your ring has bolts, you can try to set the cranks at the tight spot, then loosen all of the chainring bolts, allowing the chainring to scoot over ever-so-slightly, then tighten the bolts again. Most rings have low enough tolerances at the bolt mounts that you can get .5 mm or more by doing this.
    Low Rep Count
    Damn, you are a genius! I seriously didn't even think about trying that!
    GUIDANCE COUNSELOR
    Reputation: NoahColorado's Avatar
    Hi guys,
    Pro Bike Supply does not have the rings in-stock, be warned. There has been at this point (6/6/2012) only one production run, and that production had the imperfection mentioned (ie probably not suitable for single-speed use).
    We are currently producing more and adding 34t and 36t as well. I don't have an ETA. They are being machined right now.
    We have no plans to make the Bling Ring in any other colors.
    Cheers
    NOAH SEARS
    MRP - VP of Business Development
    Pivot Cycles - Team Rider
    mnoutain bkie rdier
    Quote Originally Posted by NoahColorado View Post
    Hi guys,
    Cheers
    Oops...I stand corrected.. apologies. Seems like you will be missing out on a ton of biz by not offering of "bling" colors...
    Why not ano them for us??
    Go ahead and check in to the Homebrewed Components thread and see what we are having to deal with. Help!!
    Reputation: jetboy23's Avatar
    At least in the X0 blue, gold, and red... please.
    Reputation: rob1035's Avatar
    Quote Originally Posted by Nubster View Post
    My big chainring says "120 BCD" on it...
    120 is offline
    Kicker of Elves
    Reputation: 120's Avatar
    Kinda disappointed with my Salsa ring. I installed this late march, probably 350 or so miles on it. Not sure how well this pic will show:
    Homebrewed Components Alternative-imageuploadedbytapatalk1339124654.114199.jpg
    Reputation: gsxrawd's Avatar
    Praxis Works
    Attached Thumbnails Attached Thumbnails Homebrewed Components Alternative-praxis1.jpg
    more skier than biker
    Nov 2006
    The Praxis Works rings are really nice. Picked up a few at Sea Otter for cheap earlier this year. Dig 'em.
    Kappius Components Ambassador - Ping me a note for a discount code
    mnoutain bkie rdier
    Quote Originally Posted by Tyrone Shoelaces View Post
    Spiderless in less than a 32t would be great!! Looks nice..
    The need for singlespeed
    Reputation: zaskaranddriver's Avatar
    Yeah, it's 80 and 120 mm bcd.
    Quote Originally Posted by rob1035 View Post
    Quote Originally Posted by zaskaranddriver View Post
    Thanks! I just got mine today and it's the same. I saw a couple sites selling them saying that they were 104 and most of the others said 120, so I wasn't sure. Kinda sux that they are 120 though, nothing out there for that size.
    Master Gardener
    May 2005
    $40 and arrived in 36 hours.
    Attached Thumbnails Attached Thumbnails Homebrewed Components Alternative-576902_4135123455198_2128945528_n.jpg
    Quote Originally Posted by Velokid1 View Post
    OK, your teaser worked ...
    Where and how and do they have 32t? Do you like it?
    Master Gardener
    May 2005
    They're perfectly round, no problems there. And yes, they are sitting on a small batch of both 32T and 34T, black like mine and also silver.
    mnoutain bkie rdier
    Awesome! Any word on a 30t??
    Master Gardener
    May 2005
    He hasn't done 30T yet but I bet he'd be open to it.
    This is RCR Fabrications, a metal fab outfit in Santa Cruz. Just google the shop # and call Josh. They do all of Todd's (Black Cat) drop-outs, etc. Todd asked them to do a small run of chainrings last year. They have just a handful left and I believe he's selling the remainder for $40-50 each. When he does the next production run, there will be a price adjustment.
    The whole RCR crew is top-shelf. Really friendly and competent folks.
    GUIDANCE COUNSELOR
    Did you mount that ring yet? We're discovering a bit of eccentricity to the SRAM splined interface (so even if the ring is "round" it'll look "off" once mounted and spun).
    NOAH SEARS
    Master Gardener
    May 2005
    Mine is mounted to the cranks as you can see, but it's not on my bike yet. A friend of mine ordered a ring at the same time and mounted it to his new FORM SS and it's perfectly round, works flawlessly. I wonder if the SRAM eccentricity is consistent from one set of cranks to the next, or if one set will have the "wobble" to it and the next won't. Do you know? First I've heard of it.
    Glass Breaker
    Aug 2005
    Quote Originally Posted by 120 View Post
    Salsa 94 mm 30t set up single speed with a 19t rear and new 8 speed chain. Died in less than 10 2-hour non-epic rides. Salsa's warranty response,"Single speed 29ers are hard on chainrings." Replaced with a Surly stainless steel.
    I won't run the Salsa rings again, even if they come in pretty colors.
    Quote Originally Posted by agentorangemen View Post
    I would have expected better from Salsa.
    Master Gardener
    May 2005
    Sorry to turbo-post in this thread...
    I've had the same experience with Salsa rings. I went through 2-3 of them before I figured out that it was them and not me (I really wanted to believe that the teeth were splaying out because of the sheer power I produce).
    I would get about 3 months out of a Salsa ring before the teeth would get so smashed/splayed that they would catch inside the chain links as the chain rolled through.
    They are junk. Salsa knows it and doesn't fix it. Says a lot about Salsa.
    You are awesome. Thank you. Finally looking forward to getting a Sram spiderless ring and not have to wait 4 months + . Spoke to a real person and they said it will be in the mail same day.
    Low Rep Count
    I am so happy to see that there are quite a few alternatives out there at this point. It sucks that there aren't much of any for the 102 bcd M960 but I suspect at some point, I will just end up getting another crank. Then again, i still haven't flipped my HBC over yet so I suspect I have some time!
    mnoutain bkie rdier
    Right on!
    Quote Originally Posted by jetboy23 View Post
    Sounds like cutting edge business practices at this point doesn't it...hahaha. Perhaps you can even expect them to deliver it and not cancel your order w/o even asking AND after waiting 2 months and receiving zero emails
    Post up and let us know your thoughts on the chainring please.
    IMO, we really need to educate any company capable of producing top notch chainrings that they stand to make some $$$ by taking out HBC.
    I know that sounds mean, but that guy has had plenty of time to rectify the BS he pulls and just doesn't seem to care enough to change anything. Oh well...biz is biz..
    Peace
    Oh..and thanks V-kid. Much appreciated
    I'm curious, MRP is also making Sram spiderless rings along with HBC and RCR. This eccentricity would seem to be evident on all spiderless rings, right? Or, what has MRP done to resolve the eccentricity you are finding with these cranks that the other offerings aren't doing?
    So the ones from Santa Cruz are round and mount on SRAM ok?
    Feb 2010
    all i use is surly stainless rings.....i like homebrewed but dont like waiting for parts. i loves me some BLING and a shiny polished surly does the job quite well......
    I think a little competition in this market segment will do well for HBC--relieving some of the pressure (both Dan's and his customers'!).
    Update with initial impressions about the RCR rings made for Black Cat-
    These aren't spaced at all. This pushed my cog closer to the dropout about 2-4mm. I believe i calculated this out to a 55mm chainline from center of my BB. Might be an issue for ppl running tensioners or freewheels.
    They fit nice on the Sram spline. A better fit than even the spider that i removed. I spun the cranks to look for a wobble at the teeth and the black center ring. No wobble at all. These appear perfectly round on my cranks.
    These have pretty skinny teeth. I'm not sure how long they will last being aluminum. I am also concerned with the tooth spacing. Top & bottom (12 and 6 o'clock) you can tell the teeth are engaging the chain and i get a tight chainline. At 3 o'clock, the chain is noticeably loose. This means it is only engaged to the chain on the top and bottom of the chainring teeth and not around the entire front teeth (say 1-5 o'clock). I can also notice noise when i spin the crank. I think this is from the teeth grabbing the chain only on the top and bottom and not evenly around the entire front side of the ring.
    I have not ridden these yet, but, my initial impression is that these rings aren't going to last long with this much "play". If RCR thinks about making a new run, they will need to fix this issue. Although, i did compare the teeth and spacing to a new Truvativ 32t SS ring and they appeared to be nearly identical. Maybe just wider teeth would fix slop with more engagement area.
    Just thought i should share so the community can make an informed decision before ordering.
    Master Gardener
    May 2005
    Much appreciated jetboy. Keep us posted. I won't have mine on a bike for another couple months. My buddy rode his 200 miles this past week and no complaints yet.
    Nov 2006
    Looks like Niner is prototyping titanium cogs:
    Spied! Titanium Niner Singlespeed Cogs - Bike Rumor
    That would resolve the super soft issues they have with the aluminum cogalicious version. Hard do drop a large bill on a cog that may be swapped for different sizes depending on the trail.
    Low Rep Count
    They look nice! I do agree though, at about $100 for a cog I think I would still go with a King and call it a day. My Surly has been holding up well and I haven't received my HBC alu version yet to compare things.
    mnoutain bkie rdier
    Quote Originally Posted by 1SPD View Post
    Looking forward to hearing about your HBC cog in May 2013.. Lets hope he sends you the correct item ordered
    Low Rep Count
    I know right! Well, the Surly is holding up well but its a 17t. My plan was to have a 16-19 set up but so far I haven't bought any new ones. I'll probably get another Surly for the 16 and 19 but will probably end up replacing the 17 with a King and probably the same for the HBC (if it doesn't come in by the end of next month). The King is pretty light and is stainless and costs about $55 but best of all are readily available! I just don't want to go have my buddies shop order me the King only to have the HBC show up the next day. Then again, I could probably sell the HBC and make a profit since I would actually ship it!
    Master Gardener
    May 2005
    Living in the mountains and running a 34x21 makes finding nifty cogs difficult. Anyone know why Chris King doesn't make anything larger than a 20T?
    Maybe the weight? Maybe wear on a 21t on aluminum is enough to not need the stainless? Maybe because 32x20 is near identical to 34x21?
    With a combination of chainring and cog you should be able to replicate the gain ratio in multiple possibilities. Now, gain ratios having the same chain length for a magic gear is another story.
    Master Gardener
    May 2005
    A few posts back in this thread, I talked about how I was blowing out Salsa rings in just a few months. I noticed the next day that my current ring, which I've been riding for a year now, is actually a Salsa. I didn't think it was. The difference is that it's a 34T, whereas I always rode a 32T before.
    So that's the primary reason I stick with the 34x21 vs the 32x20 I always ran. Drivetrain wear is dramatically reduced.
    Most people here in Prescott ride a 32x20 and a 34x21 is just a tiny bit taller.
    mnoutain bkie rdier
    Maybe you mentioned it, but why not drop the front chainring down to less than 32? More wear? How so? Just wondering...please inform
    Master Gardener
    May 2005
    The forces exerted on a drivetrain are spread out over a larger area when chainrings and cogs are larger.
    mnoutain bkie rdier
    Gotcha. I do see that most BMX streetstyle guys seem to run tiny front and rear chain ring and cog mixes though... Hmm..
    A guy I know said they do this because there are essentially less teeth to break and less chain links to break and it is lighter...
    Which is better?
    Low Rep Count
    Well, having been into the bmx scene for a while I can tell you that it also provides more clearance when doing grinds and what not.
    None the less, you will experience more and faster drive train wear with a "micro drive" set up than a more conventional 32:18 set up. It is however lighter and looks pretty cool. But a bmx chainwheel is only about $30! Chains are only about $20! And Drivers for their free hubs are pretty cheap as well unless you go with the Profile ti version. The mtb scene seems to charge alot more for these same parts and we are riding considerably further distances than the average bmx'r.
    In comparison, a top of the line rear der for a mtb (lets say an XTR) is about $200-240! A new Campy Super Record EPS 11 spd rear der is about $900! Just ridiculous! (I want one though!)
  67. #67
    Do BMX drive trains see the forces that our bikes do though? I mean BMX seems like short bursts of power that only last a very short time whereas our bikes see more sustained strain because of the length and steepness of some of the climbs we do. I could be completely off base though...I've never ridden BMX so someone correct me if I'm way off.
  68. #68
    I think bmx runs more steel rings compared to our aluminum rings. That will increase the lifespan of the smaller drivetrain. We wouldn't worry so much about wear if we had more Ti options.
  69. #69
    Perhaps more significant is the chain carries less tension when chainrings and cogs are larger.
  70. #70
    Quote Originally Posted by gsxrawd View Post
    Praxis Works
    Sweet set up
    What style XTR cranks are those? M985? or M980?
    Are they a 104 BC?
    Mojo
  71. #71
    mnoutain bkie rdier
    Singleworks Cog
    FYI...
    Posted on another thread. Steel. Affordable. Apparently pretty nice quality..
    Attached Thumbnails Attached Thumbnails Homebrewed Components Alternative-singleworks.jpg
  72. #72
    Jun 2012
    RCR rings
    Thank you so much for taking the time to write all this down! It's invaluable information to note when we are thinking about the next production run. After sending a few of these out the only complaints have come from people riding 8 speed chains. People are pretty stoked otherwise! As I have said before, these were developed for the handmade show in Austin a couple of years ago and we are just now really thinking about doing another run. We just want everybody to be satisfied with their purchase and get their product FAST. We would also like any suggestions for budget minded riders on choice setups for spiderless rings! I can't even afford to run these on my own bike! They are 7075 Aluminum so they should last quite a while. With regards to tooth thickness, we found that .082" seemed to work the best with the geometry. I believe I copied this from another ring that I had laying around the shop. The width was probably snagged from the same ring. I plan on keeping everybody posted as I get better at this forum stuff. You have to be on it to avoid getting torched! Thanks for the help!
  73. #73
    mnoutain bkie rdier
    Quote Originally Posted by rcrfab View Post
    I think we all welcome additional options if you will Please get on it and make some good bling for us. Trust me, if the product is top notch and the customer service is there, it will be a WIN WIN.
    Word spreads fast around here if you haven't noticed already..
    Thx!
  74. #74
    RCR,
    I think the "play" i noticed may originate from the tooth profile. They seem to be very vertical and the loop below each tooth where the chain roller sits is a bit wider than the roller. Since this thread is about HBC alternatives... i will use Dan's ring to compare tooth profile.
    Notice how HBC is slightly more ramped and narrower in the valley between the teeth. RCR ring is very round. 12 and 6 o'clock teeth on the RCR ring does hold the chain very well on the sides of the teeth. Its just the slight play on the valley portion around 3 o'clock that shows that these teeth are providing no support during pedaling.
    As for performance, i haven't noticed an issue yet. I do fear extra wear due to the tension on less teeth over a short period of time. The ring may hold up due to harder aluminum, but, it will wear on the chain more with all torque going into about 6 chain links instead of 12 or more.
    If this one issue was adjusted and you make more tooth counts, so far, i will be back for more. I also actually like the jelly bean cutouts. Thank you for the current support.
  75. #75
    Jun 2012
    ... and if we just ... RCR rings
    Basically, you guys rule! I am stoked for the input. Sheesh. I just want to go ride! Good news is, this all seems easily remedied. I do know somebody that has been riding his ring for over a year now and it keeps on truckin'. But, there is always room for innovation and refinement. I am going to have to bust a few out of some 6061 and check all these geometry suggestions before I go big on some 7075. Now, to Nicene Marks and that big ol' hill!
  76. #76
    Just let me know if you need a tester. I'll be happy to try out rings and give some input.
  77. #77
    mnoutain bkie rdier
    +1. I will beta test for you guys also if needed
  78. #78
    Reputation: cant fix a flat's Avatar
  79. #79
    4-5 weeks? Thats 4 months faster than HBC. Keep us (ME) updated. Thnx.
  80. #80
    Jun 2012
    Very nice rotors and ring!
  81. #81
    Jun 2012
    Bro, I got flagged for the same reason. They want you to buy an ad. $2 . I guess them's the rules.
  82. #82
    fresh fish in stock...... SuperModerator
    Reputation: CHUM's Avatar
    just so everyone is aware.
    you cannot sell on MTBR unless you purchase a $2 ad. If not your post/thread will be deleted.
    also, calling out a Mod to man up is really not that smart....ya buncha goofs.
    Click Here for Forum Rules
  83. #83
    manufacturer
    Reputation: tehan's Avatar
    ok, seems it was misunderstanding. I don't have them yet, so am not selling anything.
    This is what i designed recently.
    32T - 51g (alu 7075 T6)
    Tooth shape almost identical to E13 and i have tested this shape already on my other prototype.
    When i actually make them i will pay advertising costs for sure. Right now i am only showing what i have designed. Hope this helps. Otherwise i would have to create new thread every time i want to show what i have designed.
    Attached Thumbnails Attached Thumbnails Homebrewed Components Alternative-sram-32t-spiderless-ring.jpg
  84. #84
    mnoutain bkie rdier
    fwiw
    new xx1 looks interesting, but I like the spiderless idea a bit more. nice selection of chainrings though!
    Attached Thumbnails Attached Thumbnails Homebrewed Components Alternative-picture-1.jpg
  85. #85
    Mar 2012
    If there was any money to be made off of these I could pump out a couple dozen a day. Im working up a one off chain ring and a couple different rear cogs for my bike, then "breaking the mold". Unless these are getting made over seas, your either going to be starving or they are going to be too expensive.
  86. #86
    manufacturer
    it's not that bad if you have a friendly machine shop with some spare time in the crisis era. I have done few different cogs for myself and they are at reasonable cost. But agree that setting up cost is not low.
    to be fair i don't live from that - it's my passion so i can afford small markup. But i hear what you are saying. "made in China" is everywhere now... and it's our choice what we want to pay for.
  87. #87
    Quote Originally Posted by spity View Post
    Well, it seems there's enough market that HBC is so behind that there's a 4-6+ month lead time. Not sure how many he's making per day, but if he pumped out 12 a day at $45-100 a pop and is that far in the weeds, there must be hell of a market and some money to be made.
  88. #88
    Some of us are willing to pay a markup for an item that will actually be delivered. I wonder who made us want that?
  89. #89
    Mar 2012
    Quote Originally Posted by tehan View Post
    The passion is why we do this, but this is such a niche market. I wish you the best, and would absolutely love to see some finished products. There are so many different variables, with tooth count, bolt patterns, and mounting style. Everyone is almost a one off, (Hooray for CNC). I spent alot of time going to school to be a machinist, although its not my trade any more.
    For the right set up and the right shop yes there is, I dont think youd get rich, but I wouldnt see that someone starving to death doing it either. I dont know why hes so far behind (work load, time management, ethics, or otherwise). I couldnt pull it off. The family machine shop thats been around for 50+ years is billing out a couple hundred dollars an hour on current projects. If we were making these we'd be starving.
    If you made 12 a day at 252 business days a year(3000ish total), sold them at 45-100 each your looking at your looking at between 130k-300k(costs are not figured in). Good luck selling 3,000 of them. Realisticly cut your sales to a couple hundred tops, calculate your time, materials, shipping, etc. Dont forget uncle sams cut! If it pays for your new bike this year your ahead of the game.
    Im not trying to start a war here, but trust me I wanted to do this. Passion doesnt pay my bills.
  90. #90
    Jun 2012
    I have received quite a few inquiries for custom rings and the like. As RCR is a general fabrication and machine shop, we tend to work better with the design already done. Take the thinking and trial and error out of the equation. Provide your own CAD drawings where geometry can be grabbed for CNC easily. You will save a lot. Design time is still at the same shop rate so it can add up when just general guidelines are given. I do think there is a market for our rings but it is very difficult to compete with Taiwan and China once they get there s--t together. So far, we have a big hole we have to dig out of before we even think about making any money on these things of bling.
  91. #91
    RCR,
    Honestly, your design is already working. But, would be better with 2 fixes... A slightly wider mounting area to bring the ring inward a slight bit (only needed for those who want to run a chainguide really) and fix the tooth profiles. The teeth on my e.13 has a good fit on the chain. Just wish they were a millimeter taller. Other than that, its good. That said, if i knew CAD i would get this to you asap.
    Btw, i just did a 30 mile ride with your ring. Mostly great, but, 2 times i got a slight "thump" that i felt with my pedals. I have only got this since adding the ring. I think its the feeling when the chain settles. I can't confirm, but, still believe the tooth profiles are the cause of this.
  92. #92
    Jun 2012
    Technology is awesome isn't it? Without it, those two suggestions would have taken days, weeks or months to get to me. Both are things that I am incorporating into the next incarnation of these rings. CAD work has already begun! I am selling these off, at a loss, and am stoked on the valuable information that I am gathering. This run was made with the input of just a couple of people testing. Now I have a couple dozen. Thank you so much for your purchase and the help!
  93. #93
    Master Gardener
    May 2005
    You're a good man, Josh.
    I wish my new Black Cat dropouts had a tiny hummingbird etched into them so I could represent on the rear of the bike, too!
  94. #94
    Colors...colors would help sell as well. I mean when you get right down to it, a reasonably price high quality product should be enough, but offering a little bling won't hurt either.
  95. #95
    RCR, to better show what i'm talking about with the tooth profile i have taken pictures to point out the "play". I know you got something in the works, just wanted to put an image to the text
    Attached Thumbnails Attached Thumbnails Homebrewed Components Alternative-rcr-ring-1.jpg
  96. #96
    manufacturer
    it's not a tooth profile. I had same problem with my very early designs as well.
    It's the spacing of the tooth - seems calculation was wrong for circumference. You will get it wrong by 0.02mm on tooth spacing and after 15 tooths you get 0.3mm error.
  97. #97
    Jun 2012
    Jetboy23,
    Nice shots! Tehan is right. Totally looks like a circumference issue. Is that an 8, 9 or 10 speed chain?
    Nubster,
    All the kids are asking for the candy colors! Sounds like a good idea to me!
    Velokid,
    Those dropouts are all Todd, and all Black Cat. I wish I was as cool as Todd. He just provided the .dxf file and we crap em' out on the the ol' waterjet. Bike parts from email? Awesome.
  98. #98
    Chain is a KMC z610hx. No ramps for gears. It was a perfect fit on my e.13 guidering. Maybe i'll pull out a 9sp chain and try the fit sometime.
  99. #99
    Aren't you the guy that offline threaten to beat Dan up? Still butt hurt he canceled your order?
  100. #100
    Rhino
    Reputation: urbanseeds's Avatar
    this has probably been beat to death in the SS forum, but I couldn't find it. Can someone school me on the pros/cons spidered vs. spiderless. I am building a new ride and all I have ever used is spidered, and wondering about spiderless. thanks.
  101. #101
    No chain ring bolts, slightly less weight and IMO better looking.
  102. #102
    I'm going spiderless to reduce a bit of weight (main reason), possible tooth counts under 32, and a cleaner look. I lose the bling options of colors (unless you go with HBC) since MRP and RCR are currently 1-2 color options. And, only HBC is doing Ti (my ultimate dream).
  103. #103
    mnoutain bkie rdier
    Quote Originally Posted by WebInt View Post
    Haha. Good one.
    Again, are you Dan? No, I didn't threaten Dan. Perhaps he felt threatened by me when I told him I would like to speak with him in person a year ago.
    Today, there would be a huge line of folks wanting to have a word face to face with Dan. You doubt this??
    It was not a threat, but I guess it could have perceived as one.
    I don't doubt that Dan is a good guy. It did bother me how he responded to me and my concerns way back when...struck me as a bit arrogant, as others have picked up on too..
  104. #104
    Haha. Good one.
    So move on from talking trash about his company every chance you get. You don't even ride his stuff. You never bought anything from him either as he canceled your order. That's my point. I get others complaining that paid for stuff and don't have it or are still waiting. I would be pissed too. Again, you simply come off as a woman scorned.
  105. #105
    mnoutain bkie rdier
    Nearly a year passed without me saying a word.
  106. #106
    Thanks for the PM. Much easier that way.
  107. #107
    Reputation: AtotheZ's Avatar
    Nov 2007
    Almost as bad as posting the same thing on two different threads
  108. #108
    I would think those Velo's are the same as all the other 7075 4 bolt 104bcd rings. In my opinion, these rings are very similar in performance and longevity. Just find one thats a color you want and go either weight weenie or not. HBC makes beautiful rings for this application. At least from the pics i've seen of them (no, my account wasn't hacked just because i said something nice about HBC). With this application, its a pick your flavor type of thing.
    We really need to see the offerings that are in the more custom area of the less common bolt patterns or spiderless for mountain biking. Also, still waiting for a spiderless SRAM titanium option. 30t Sram spiderless Ti ring is my dream.
  109. #109
    May 2010
    Just received my black RCR 34t. Beautiful work and from Santa Cruz to TX in under 48hrs! Will post about it after the rain stops and I can get some miles on it....
  110. #110
    bling is in
    nice fit... now which bike to mount you too??
    Attached Thumbnails Attached Thumbnails Homebrewed Components Alternative-mtbr1.jpg
  111. #111
    mnoutain bkie rdier
    Looks great Chester.. Roundness?
  112. #112
    Thanks, it measures round. This one is new and not from the original (flawed) batch not recommended for ss use. I'll slap it on soon and report back after some abuse
  113. #113
    Unpredictable
    Reputation: Ridnparadise's Avatar
    Quote Originally Posted by fryed_1 View Post
    How does SRAM come into a SS thread? As a newb I thought SS = SS?
  114. #114
    Quote Originally Posted by Ridnparadise View Post
    Because the quote on your post is referring to the fact that the Bling Rings are made to only work with SRAM cranks.
  115. #115
    mnoutain bkie rdier
    Weight diff?
    Anyone know the weight diff between the carbon XO crank ARMS vs the X9 crank ARMS...aka w/o chainrings but with spindle of course..
    Thx.
  116. #116
    Unpredictable
    That's makes so much sense only an idiot would have failed to work it out! Oh wait...
  117. #117
    I went through a fair bit of agony getting my chainline set to use a freewheel and an HBC chainwheel. Looks like the MRP wouldn't work on my setup since it's dished. How much chainline offset results from the dishing?
  118. #118
    Reputation: boostin's Avatar
    Hows that RCR ring holding up?
    Besides the RCR and Bling Ring's what is available for the Sram spiderless interface? HBC isn't on the radar anymore I'm afraid. Is Boone making one?
  119. #119
    I took the RCR ring off due to some slop around the teeth. It was running fine as far as i know. I hadn't dropped a chain from the slop. In the 150mi i ran it, it seemed to wear fine, too. I just didn't want to be 15-20mi from my car and have an issue. It seemed like the load was being placed solely on 5-8 teeth compared to the full chain contact area.
    Since MRP came out, i've been running that and have been very pleased. I wish they made odd tooth rings as well. Would have loved Ti. But, my 30t seems to be wearing well and shows little to no signs of wear after about 600-800mi.
  120. #120
    Dr. Pepper drinker
    Reputation: catch22's Avatar
    I'm a little late to this thread but check out North Shore Billet for some great new SRAM spiderless chainrings. Just ordered up a 31t today. I suspect I'll see this one just a bit sooner than the HBC 104 BCD that i ordered 9 months ago and no longer have a use for.
  121. #121
    Reputation: bikeny's Avatar
    Titanium alternative:
    I haven't seen it mentioned here yet, but there is another option for titanium spiderless chainrings:
    .:: Carbon-Ti - Hi Tech Bicycle Components ::.
    They are available 32t through 36t for Cannondale, Specialized, & SRAM/Truvativ.
    I just received one, ordered through their US distributor, Apollo Components.
    I have not used it yet, but it looks nice, although not as blingy as the HBC I am running now. Will try to get a picture up.
  122. #122
    How about some carbon chainring/sprocket?
    https://shrani.si/f/1b/Md/1J3z3A3n/aj.jpg
  123. #123
    Quote Originally Posted by giantdale View Post
    Can it handle the abuse?
  124. #124
    Would you have a heart to abuse such beauties? Nothing but tender loving care!
  125. #125
    Here are some pictures of the Carbon-Ti spiderless ring. Looks really nice, and only weighs 62 grams.
    Attached Thumbnails Attached Thumbnails Homebrewed Components Alternative-carbo-ti-34t-ring-1.jpg
  126. #126
    mnoutain bkie rdier
    Quote Originally Posted by bikeny View Post
    Wow! How much did that cost you? Looks thin/flexy..
  127. #127
    They do look pretty "foldable", but pretty.
  128. #128
    Cost was $160 delivered, a touch more than an HBC Ti ring cost when available.
  129. #129
    Did I catch a niner+?
    <a href="https://beta.photobucket.com/" target="_blank"><img src="https://img.photobucket.com/albums/v319/mrpink57/Bike/2013-02-11_13-28-23_172_zps1394f6c4.jpg" border="0" alt=" photo 2013-02-11_13-28-23_172_zps1394f6c4.jpg"/></a>
    Rennen is pretty alright in my book. I have not been able to ride it yet due to weather but I have owned to HBC chainrings in the past which one bent in half and the other I sold. Compared to HBC I think they're about the same expect I think Dan did a better ano job.
    <a href="https://beta.photobucket.com/" target="_blank"><img src="https://img.photobucket.com/albums/v319/mrpink57/Bike/7ec31f66d2f84e1f9d3101ea6037c545_zps8804f1a2.jpg" border="0" alt=" photo 7ec31f66d2f84e1f9d3101ea6037c545_zps8804f1a2.jpg"/></a>
    wolftoothcomponents.com
    Anyone use this guy? He is right in my backyard but had no idea.
  130. #130
    Cheesiest
    Reputation: intheways's Avatar
    Any word on other options? Any one out there do custom cut-outs?
    "Paved roads...just another example of needless government spending"—paraphrased from rhino_adv
  131. #131
    manufacturer
    ABSOLUTE BLACK Kettenblatt Spider für Sram GXP Kurbel blau 51g, 54,50
    available in 4 colours and few sizes. i think they will be soon available in US.Homebrewed Components Alternative-absolute-black-kettenblatt-spider-sram-gxp-kurbel-28-30-32-34-rot.jpg
    Homebrewed Components Alternative-absolute-black-kettenblatt-spider-sram-gxp-kurbel-28-30-32-34-blau.jpg
    Homebrewed Components Alternative-absolute-black-kettenblatt-spider-sram-gxp-kurbel-28-30-32-34-gruen.jpg
  132. #132
    Jun 2005
    absolutely
    Quote Originally Posted by intheways View Post
    We've been working very hard around the clock designing, engineering and testing our direct mount spiderless chainwheels for X0/X9 compatible cranks. We've been testing the optimal chainline extensively this week and will go into production next week and will start taking pre-orders then. All of our spiderless chainwheels will be available anodized Black, Red, Blue, Brown, Yellow, Purple, Green, Orange, Grey and Pink
    Attached is our 28T Spiderless Cyclone Chainwheel which is being tested:
Size:  84.1 KBName:  28T-warhawk-cyclone-spiderless-chainwheel-2.jpg
    Yes we already offer this service, if you have a CAD drawing you can email it to us or send us a PDF of your design and we'll let you know if it's possible. If you need a CAD template just let us know and we can send you one in dwg/dxf format.
    Warhawk Industries - Specializing in Stainless Steel, Titanium and Aluminum Chainrings
  133. #133
    available in 4 colours and few sizes. i think they will be soon available in US.Click image for larger version.
    What's up with the weird decorative lines that serve no purpose other than to increase cost?
  134. #134
    All these grooves for decoration and minimal weight decrease would seem to only be a great crevice for dirt and grim to accumulate. Cleaner is better imo. Those Absolute Blacks look real nice, though. Just could do without the squiggles.
  135. #135
    manufacturer
    they are cheaper than Bling Ring by 10$ so where you see the cost increase?
  136. #136
    ~ B A D A S S ~
    Reputation: car bone's Avatar
    That a milled ring. You can make all the machining in a mill. those grooves are the machine marks aftewr milling the dish with a small ballshaped/halfsphere tool. a 3 axis machine that is.
    Otherwise you need to oput it in a lathe to get the dish. 2 machines, instead of 1. Also a lathe with live (spinning) tools can be used and then you can make it all in one single machine too.
    Or it could be cosmetic. I don't care for that look at all. Looks suboptimal to me.
    Rule #9 // If you are out riding in bad weather, it means you are a badass. Period.
    Quote Originally Posted by iheartbicycles View Post
    Specialized sucks ass.
  137. #137
    MRP Bling Ring is about $65 (average US dollars) and the 54Euro converts to $70. More expensive.
  138. #138
    mnoutain bkie rdier
    Will be racing remainder of season on MRP Bling Ring 1X10 set up. Sram crankset.
    EDIT: Well, nope ;(
    After taking my crankset apart and installing the nice Bling Ring, I reinstalled the crankset.
    Hmm... Why is the ring nearly touching my chainstay and why is it WAY off from my newly purchased E13 guide?
    Answer: Bling Rings can not be used on PF30 BBs. The spindle is too short! Well...crap in a hand basket!!!
    To MRP's credit, on their site, it does mention that they are to be used with GXP type only...but it was like finding a needle in a haystack on their site.....argh.
    Gave me an excuse to spend another G on my bike..haha. Just went with the XX1.
    Frame is NINER RDO fwiw...
  139. #139
    manufacturer
    I think you forgot that it is German shop (Europe). So if you buy from US you don't pay vat. So it works out to 45 eur that means 59$ with current exchange rate. Shipping is not expensive either. So it works out cheaper.
  140. #140
    Really? World wide shipping 35Euros.
  141. #141
    I do like the red, but loss the extra marks please. Form should follow function.
  142. #142
    manufacturer
    seems i missed that 35eur shipping. But anyway it works cheaper excluding shipping. So paying 60$ in US from US shop would be ok i guess.
    These markings are because of technology used. This gives ideally round chainrings as it's done from one clamp. Not like putting material on lathe and then mill (mrp does that - thus early problems with roundness). Here all is done on the mill and these grooves are really tiny and shallow. So function is on first place. It works Making it really smooth would increase cost actually.Homebrewed Components Alternative-closeup.jpg
  143. #143
    If only i could get a Sram splined Ti ring.
    tehan, if the AB rings got a US distributor, i would probably try them out. For now, MRP is working great and wear has been really good.
  144. #144
    manufacturer
    haha. Don't know if you have tried ti chainrings, but my experience with Ti cassettes and chain was poor. I expected longer life due to material properties, but it turned out that it dies as quickly as steel ones. So am not sure anymore if there is a big sense to that apart of the bling of Ti.
    I have also on one of my bikes a 40T titanium (Carbon-Ti) ring and wear rate is very comparable to the aluminum one it replaced. The only difference it that Ti one cost me 3x more
    Of course there are methods to reduce wear on titanium but they cost a fortune, so already expensive ring gets just even more expensive.
  145. #145
    nothing to see here
    Reputation: Stevob's Avatar
    Personally I like the look of the absolute black chainrings. Squiggly lines included.
    I see hills.
    I want to climb them.
  146. #146
    manufacturer
    Best part is the weight:
    MRP: 28t -53g, 30t -58g, 32t -72g, 34t -85g, & 36t -94g
    Absolute Black: 28t -44g, 30t -48g, 32t -51g, 34t -67g, (36 in the works)
    NSB: 28t -75g, 30t -85g, 32t-95g, 34t -105g, 36t -120g
    This is 30% lighter than MRP and almost 45% than NSB. Finite element testing and "funny lines" can pay of very nicely. At the end of the day who does not want to have a bit lighter bike here and there, which is reliable as heavier bike and cost you exactly the same?
  147. #147
    Now I'm interested, funny lines included! Since these are a result of the milling process and not added for decoration, I don't mind and I like red. How are the tooth profiles and how do they preform?
  148. #148
    Sorry, I'm a little confused here - who's based out of Germany? I'm asking because I'm in Germany now, and am really interested in a spiderless ring for my single speed, albeit a shimano crank...
  149. #149
    Quote Originally Posted by cdn-dave View Post
    The Absolute Black Sram rings are based out of Germany. Not sure if they have shimano splined.
  150. #150
    manufacturer
    Tooth profiles are very similar to the ones from e13 single chainrings. Proven and reliable. I have tested tooth profiles on other rings in my singlespeed 29er (33x18) for over two years and am still able to use same ring with new chain! (pictures will follow on monday)
    Tried these also with no bash/chain keeper (but with type 2 rear mech) and chain retention is really good. For the stuff i ride (wet roots, rough, often muddy terrain) is perfect. But for rockgardens i guess a bashring and chainkeeper would be a good idea - if you tend to hit a lot with a chainring.
    Anyway, if you hit something often a bottom bashguard is wise to have. There is no such chainring which can take brutal abuse from rocks and keep straight all the time. It's because it does not matter how wide is the base of the ring - tooths are only 1.9mm in all chainrings and they simply can't take big hits and remain straight.
    forgot. About those funny lines. Extralight products are made in same way so you can see their crank here:
    QRC 2
    Same with All Hope brakes (levers, bodies and calipers)
  151. #151
    QRC 2
    So how do we get in the US? I had a bling ring on order and it's backordered for a while ...
  152. #152
    manufacturer
    I am working on it right now.
    First production should be in US within 5 weeks. Will keep you posted.
    Few photos from todays ride.
    Yes it's UK and we have snow from yesterday... with mud. This is a custom brown color in case anyone wonders. This setup is with XX casette (12-36) and X0 rear mech and 32T on the front. I know i have a front mech still on... but chain retention is very good like it is on the photo, so i have not put any chainguide yet - as maybe i will not have to buy one. There is absolutely no problem with chain line in such setup. What i found is in most cases one rides in mid section of casette anyway for 60% of time, so chain is almost straight then.
  153. #153
    Okay. Not sure if it makes a difference to anyone, but here's why I was confused, according to their website:
    "We are based in Woburn, UK so please mind on local time."
    In any case, they can't do a shimano version at this time...
  154. #154
    Fat & Single
    Reputation: ozzybmx's Avatar
    Quote Originally Posted by Mr Pink57 View Post
    Already posted this on another thread. Drop-stop teeth (XX1 style) allow use without a chainkeeper, im running a standard X0 short cage and 10spd chain with no problems so far.
    Apologies for the crap photos, camera setting were wrong.
    Santa Cruz Hightower LT Evil Following Trek 9.9 Superfly SL IndyFab Deluxe 29 Pivot Vault CX Cervelo R3 Disc
  155. #155
    manufacturer
    We are based in UK What you have seen in the link is our Dealer web shop in Germany. I am in process of updating our own web site with the product, but our German dealer is quicker then me
    What spines are you interested in for Shimano? I mean do you speak about spiderless version or 104BCD XX1 style rings?
  156. #156
    Reputation: bkirby10's Avatar
    Feb 2012
    I still like the old-school XTR 950/951/952 cranks. Any chance for a spider less ring for them? HBC was the only one left that I was able to find...
  157. #157
    Jun 2005
    XTR M952 Splined Chainrings
    Quote Originally Posted by bkirby10 View Post
    Hi bkirby, I'll have these available by the end of the week, if you would like to test one out and provide feedback shoot us an email. The old 95x series are our favorite too, I plan on putting the 952's on my singlespeed build this summer, let us know, Thanks - Colin
  158. #158
    manufacturer
    I will think about those as well. At the end of the day it's just a spline interface change + small adjustment.
  159. #159
    manufacturer
    ok, finally i have sorted the site.
    You can purchase chainrings here: Sram Spiderless
    it's 60$ +14$ for shipping to US and Canada.
    Any questions or problems - let me know
  160. #160
    Feb 2012
    What are the possibilities for a Shimano spiderless ring? Undrstood if it takes a while but still wondering...
  161. #161
    manufacturer
    I will do them, but it will take some time. Design is not a problem now - it's all about setup of CNC to do it in right money. This takes a lot of time to set up a line and make tools to hold the chainring while machining. It's not a printer or a garage tinkering.
  162. #162
    Feb 2012
    Understandable. Let us know if/when you get it done. There has got to be a few older guys besides me who love the older Shimano cranks (V1 or square taper BBs)...
  163. #163
    Are they in stock and shipping? How about red?
  164. #164
    one chain loop
    Reputation: fishcreek's Avatar
    count me in.
    everything sucks but my vacuum cleaner.
  165. #165
    manufacturer
    all is on the site. All sizes and colours will be in stock in first week of May. We are now milling as we speak.
    You can preorder and this will get you ahead of the queue as dealers have preordered quite a lot as well, so we have to meet the demand.
    Watch out Bikerumor as well as i have sent them red for test, so they should get it next week.
  166. #166
    And you promise they're round, right?
  167. #167
    manufacturer
    i can put my hand on that. You have to understand how they are made.
    MRP uses lathe first to make a dish. Then they put it on the mill to get the tooth shape and rest of holes. This is risky and you have to be very careful to not to get it out of center when mounting to mill.
    Mine are done from one Clamp on the same cnc mill table. That means crank interface and tooths are made from one clamp and there is no way to make it out of true. It is just not possible that way to make it bad. This allows me as well to drop the cost of milling by a bit, so i can offer them to you at lower cost than MRP or NSB -simple. Not everyone can do that as it requires very fancy and expensive tools to do it that way.
  168. #168
    Thanks, I'm going to try out a red one!
  169. #169
    ~ B A D A S S ~
    You could probably write a program that first measures/probes and then makes an automatic datum shift (or just rezero) for each piece, and the only "cost" would be the time it takes for the probing and shifting in that tool. Its not that hard to get stuff centered though. i did some 200 round pieces once that were for ultra high speed spindles, everything needed to be perfectly balanced when done, clamped them in the mill with one of those chucks that have 3 points (like in a lathe). And while you think this would center the pieces right?? They were off by about 0,2 mm all off them and that was unacceptable for those pieces. Had to do a datum shift/new zero for each piece. 0.2mm out of center is not that much for a chainring imo. to get that accuracy you only need operators that are not monkeys or retarded. Nothing special is needed.
  170. #170
    ~ B A D A S S ~
    Depending on how much material is removed and condition of the material, how the material is removed and internal tensions and stress that gets relieved and crap like that, hardening before or after machining etc, stuff can get out of round/warped after all machining is done, it happens. and the more material you remove and the more aggressive you remove in the least amount of steps the more likely it is to happen. To avoid this precision stuff is always machined to leave room for this until the last step which only removes like 0.1 or 0.2 mm, usually by grinding instead of machining. Not one single part on a bike is a high precision/tight tolerance component though (imo)
  171. #171
    Quote Originally Posted by fishcreek View Post
    count me in.
    Looking forward to it too!
  172. #172
    Reputation: OldHouseMan's Avatar
    Is anybody making Sram spiderless 39-40T chainrings? I'm looking for a chainring to put on the Sram S950 crankset on my CX bike.
    I only ride bikes to fill the time when I'm not skiing.
  173. #173
    Dec 2011
    Tehan, what's the offset of your rings. Can you show some horizontal pics with measurement to compare to other options in the thread?
  174. #174
    manufacturer
    Quote Originally Posted by car bone View Post
    Hi, this is all fine when you want to make one at a time - then i fully agree. But if you are making 20 at one go on the table... it's not possible (or rather waste of time to make it cost effective)
  175. #175
    manufacturer
    Quote Originally Posted by Dcluley98 View Post
    all is on the website. Chainline is 50.5mm. That means that the chainring will sit exactly where your middle one is on the triple set crank. So it is identical to MRP in that matter. This is the best spot for the chainring as it works well with upper and lower gears of the cassette.
    So simple answer- chainring is dished, not flat.
  176. #176
    Feb 2007
    It looks like Wolf Tooth is shipping spiderless wide/narrow (a la XX1) this week if you are geared and want to avoid the chain keeper...
    Direct Mount for SRAM GXP Cranks
  177. #177
    Reputation: WolfTooth's Avatar
    That's right! They will be here soon and as you can see in the link we are taking pre-orders.
  178. #178
    manufacturer
    Quote Originally Posted by bjmoore1 View Post
    You can avoid chain keeper with mine as well. New production Tooths are slightly different to the photos i showed sometime ago now. I was holding it back to the last minute to wait for test results from pro riders - and they came excellent.
    What we found out is that we can avoid having wide/narrow tooths and retain chain same way as XX1 - all the magic is in the tooth shape itself . In May you will be able to find out yourself. Good news is that i can still keep 60$ retail and you don't need chain keeper.
    you can pre-order now as well on the web.
    exciting times!!
  179. #179
    exciting times!!
    I am taking your word for this - just ordered one of your 32t rings in black (scott in Canada) most excited about the weight loss over the MRP 32t direct mount!
    Do you feel it will be reliable enough for XC racing with no chain-guide and a clutch rear derail on a hardtail?
  180. #180
    How soon will these ship? I need a red one to bling up my humble Monkey.
  181. #181
    Reputation: ecthelion's Avatar
    EDIT: Well, nope ;(
    Yeah, the Bling ring and BB30 or PF30 is tough. Mine works on my BB30 Quiring ONLY because it's a 28t ring, and clearance at the chainstay is barely enough. If I ever go to a bigger ring up front it won't be a MRP Bling Ring.
    Quiring KVA MS2 29er SS
    Quiring XCr Road
    Tallboy Carbon
    Fisticuff
    ARR | IMBA NMBP
  182. #182
    manufacturer
    before 15th May (so in about 4 weeks). Sorry can't rush it more than i already done. Everyone need to sleep from time to time and having 16h day, every day, is not something one can do in long run.
  183. #183
    Tehan, this is great info. Please do let us know when these new version will be available to order. I need me some spiderless blue bling. If only i could get Ti...
  184. #184
    manufacturer
    Quote Originally Posted by broadwayline View Post
    Hi Scott, thanks for a business!
    I don't see any problem with XC riding and chain retention. Only really aggresive enduro riders or some serious downhillers should use chainkeeper as there is no miracles. When you ride really big stuff, chain does what it wants, so even best ring will not handle it on its own. But regular stuff what people mostly do is no problem.
  185. #185
    manufacturer
    Hi jetboy,
    You can preorder now if you want on the web. Shipping is in middle of May as stated on the site.
    To make it clear - chainrings you see on my site currently ARE the new design. So what you order now is that new design. I will not make old one anymore as there is no point in that.
    Will change photos as soon as i get them from photo studio to not confusing more.
  186. #186
    Jun 2010
    If it hasn't already been covered, North Shore Billet makes nice spiderless chainrings and has them in stock ready to ship.
  187. #187
    F2a
    F2a is offline
    Tehan, how are the rings coming along? I'm interested but don't want to pre-order after getting scammed by homebrewed components.
  188. #188
    Quote Originally Posted by F2a View Post
    Funny you posted that. I just pre-ordered 2hrs ago. lol. Can't wait to try them out. I will pay attention to the 45 day cuttoff, though.
  189. #189
    manufacturer
    They are milled already. Now i need to get them to anodizing plant which should take no more than 12 days according to shedule (1-3rd is national holiday where i make them) so can't get it done quicker.
    If i can't keep the date stated on my site - you will get your money back at the same minute you tell me to do so. I am here not to get just few bucks come on guys... The main difference between me and Hb is that i don't do all the stuff by myself- that would be suicide. So i hire professionals to make the chainrings for me. I am best at design and they are at milling the stuff. So i have time to answer your emails and deal with distributors.
    Jetboy - your blue ring will be made along with everyone else. don't worry. I have found distributor in US finally, so soon it will be easier for you guys to get them there. How soon? - don't know yet.
  190. #190
    one chain loop
    Tehan, forgive my ignorance, will you chainring work on Bontrager Race Lites?
  191. #191
    manufacturer
    If you are talking about RL 104BCD crank then this will not fit (only bontrager i remember is the carbon one made by truvativ - this would work)
    But don't worry. I am launching soon XX1 style chainrings for 104BCD. These should be done by end May - more news soon on those.
    XX1 STYLE - Shimano
  192. #192
    tehan, i wasn't suggesting that there will be an issue. I'm very excited to get one of these rings. I'm shocked that you're on top of orders enough to know it was a blue one that i ordered. Thats awesome.
    I am waiting patiently, just not for more than 44 days. lol.
  193. #193
    Jun 2005
    warhawk spiderless chainrings
    I just added our hurricane spiderless chainring to our growing collection of spiderless chainring designs. I'm keeping several ring sizes in-stock and utilize JIT (Just-in-Time) manufacturing meaning that even if we don't have a chainring in-stock it only takes a few hours from the time the order is received to machine and ship the part. Our rings have been tested extensively and we are now machining these rings with our new taller tooth profile which will be the same tooth profile used on our soon to be released XX1 compatible chainrings. If you have any questions let us know, Thanks - Colin
  194. #194
    Do you have any weights for those rings?
  195. #195
    Jun 2005
    Sure no problem, I just weighed these here at the shop:
    Warhawk Industries Hurricane
    Spiderless Chainring
    Weights:
    28T(68g), 30T(74g), 32T(87g), 34T(112g), 36T(124g)
    The hurricane design is not the heaviest or the lightest among other rings but remember take into consideration the weight to strength ratio. Our rings are ~40% stronger then the lightest competitors ring. If you case a log crossing or need to pivot over a log you don't have to worry about bending one of our rings. If you have any other questions just let me know and I'll get some of the other weights up for our other designs soon, Thanks - Colin
  196. #196
    Quote Originally Posted by Warhawk View Post
    Weights:
    Great info! I was expecting them to be heavier, but they look like a great strength to weight alternative.
  197. #197
    Feb 2012
    Just wondering if anyone has any more plans for Shimano spiderless rings? Haven't heard anything in a while and was just wondering...
  198. #198
    manufacturer
    jetboy - it was kind of luck that i know it's you but figured that out.
    Weights:
    Warhawk - thanks for weights. I missed them on my site for comparison chart.
    Since mine are the lightest out there i am just curious how did you come up with that 40% stronger value. I am specifically interested in your back calculation... will you share with us?
    Besides, Tank is stronger than a family car by "500%"(i picked that number as it looks good). But people ain't drive tanks on the street as most of them figured out that car is safe enough to drive...
    That's why FEA is so brilliant as you can take weight off of the part without scarifying the strength. I am not the only one who discovered that feature you know
    Secondly - if you pick a lot stronger material, then you can make a lighter part. Since i use the strongest aluminum currently available to public, i can also shave a lot more weight. I have missed on your site what material you use, so don't want to comment more on that.
    To make story short. Heavier does not necessary mean it is stronger. These things does not go in common when using different materials and FEA (i know it sound wired for some but that is true). Sometimes heavier means weaker - for those who used FEA i don't have to write more. For others - heavier means more rigid in most cases, and rigidity is not a good thing in some applications and some axis (don't think about chainrings but about all the engineered parts). It's a very large topic...
    It's not arguing. I just noticed in general that people sometimes make statements without any backup in calculations. So wanted to shed more light on the topic which is very interesting on its own. FEA is a blessing of modern times. Just look back 30years ago and look how heavy many things were. This was because lack of performance materials and lack of calculations. Imagine yourself calculation on paper of 500,000 points in FEA analysis... no go. (well some airspace and car companies did that with 100s of mathematicians, but it's an exception)
    ok enough moaning.
  199. #199
    Jun 2005
    We have a few out on the trails being tested right now and plan on having these available within a few days. I'll post a reply when they are ready to order, Thanks - Colin
  200. #200
    As long as a chainring can handle my less than incredible strength, i'm good. If i drop my ring on a log, or rock, or anything really... then i fully expect it to take damage like any other chainring not built for bmx freestyle or trials riding. Maybe some will handle the abuse, maybe some won't. I expect them all to fail if i abuse them though. So, i don't.
Page 1 of 2 12 LastLast
