Homebrewed chainring and Specialized cranks- Mtbr.com
Results 1 to 11 of 11
    I love my new crank setup. Homebrewed spiderless Ti chainring, Specialized 180mm cranks and Zipp Vumaquad bearings. This is on my 2011 Stumpjumper SS.
    Attached Thumbnails Attached Thumbnails Homebrewed chainring and Specialized cranks-cranks-pic-2.jpg
    Ovaries on the Outside
    Reputation: umarth's Avatar
    Holy **** that is cooler than I thought it would be.
    CB2
    CB2 is offline
    Jam Econo
    Reputation: CB2's Avatar
    Is it the camera angle or how close is the ring to the chainstay?
    Quote Originally Posted by CB2 View Post
    The pic is deceiving. There is plenty of room between the ring and the chainstay.
    A different view.
    Attached Thumbnails Attached Thumbnails Homebrewed chainring and Specialized cranks-zipp-bb.jpg
    The need for singlespeed
    Reputation: zaskaranddriver's Avatar
    Two sexy crank threads in one day? Oh, my.
    SS XC Junkie
    Reputation: dontheclysdale's Avatar
    Those cranks are cool and even more cool is the little pedal strike caps at the end of the arms. I would caution you to put some threadlock on the bolt that joins the cranks together and tighten that thing way above the spec's. I had these on my stumpjumper and they came loose in the middle of a race. Not cool, and while I managed to scavenge an allen wrench that was long enough to tighten them from a passing racer, I couldn't put enough torque on them to stay together. You need a socket and ratchet to tighten them to or beyond spec. It also happened to one of my teammates on his stumpy.
    They're nice, light, and stiff but if they ever come loose on you you'll hate them for life. I have a pair of Lightnings (the non s-works branded predecessor of these) that I gave a teammate because I just couldn't put any trust in them anymore and didn't want to put them on any of my bikes. I actually broke one of the arms (Lighting replaced it under warranty) on that set and then after the s-works came loose on my 2x10 bike I completely gave up on that design. With that said, there's a lot of people riding them and a lot of people who swear by them. Unfortunately my experience with them was jinxed.
    Mtbr Forum Sponsor - Homebrewed Components
    ha, you have the only ring in existance for that crank. Looks awesome, thanks for the pics!
    [QUOTE=dontheclysdale;8576577]Those cranks are cool and even more cool is the little pedal strike caps at the end of the arms. I would caution you to put some threadlock on the bolt that joins the cranks together and tighten that thing way above the spec's. QUOTE]
    I've been keeping on eye on the bolt over the past 2 months. So far, so good. The crank protectors I re-used from my RaceFace crankset that I took off.
    Quote Originally Posted by ISuckAtRiding View Post
    Wow! Didn't realize that it was the only one you've made for the S-Works cranks. Very cool!
    want
    crash expert, ss convert
  1. STX cranks chainring ?
    By kvojr in forum Singlespeed
    Last Post: 11-28-2010, 05:28 PM
  2. XTR Cranks, what chainring?
    By MisterC in forum Singlespeed
    Last Post: 04-05-2009, 08:00 AM
  3. BMX cranks and chainring for 1x9?
    By BoxCarPhoto in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-04-2008, 11:30 AM
  4. SS Chainring for XTR 952 cranks
    By alohavolley in forum Singlespeed
    Last Post: 12-18-2006, 03:41 PM
  5. 30t Chainring for XTR 952 cranks?
    By Francine in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-22-2006, 09:52 PM
