Hex chainring bolts -- out there?- Mtbr.com
Results 1 to 24 of 24
    Out spokin'
    Dec 1999
    I have a set of chainring bolts with a traditional Allen head screw but a hex nut
    instead of the common but miserable big flat screwdriver type nut. The hex ones
    are awesome. They came on a crank I bought 2nd hand. Anyway, I want some
    more like them or dual-Allen head but SS-specific.
    I found these on AE Bike
    (Crank Bros. Cobalt chainring bolt set) but I see a couple of problems.
    First, there are only 4 screws/bolts in this set and my cranks have a
    5-bolt spider. Second, the nut looks like it's made for double ring
    applications, not SS.
    Can somebody point me in the right direction?
    Thanks,
    Sparty
    disciplesofdirt.org
    Well, I know both of my Truvativ SS cranksets have the allen head bolts, but both are long for a chainring and a bashguard. But they sell one ring cranksets so you might be able to find some that work. You want ~6mm ones
    blame me for missed rides
    Reputation: weather's Avatar
    well, grind em down...
    mudnthebloodnthebeer
    Reputation: quaffimodo's Avatar
    Sure. Over there...where the grinder is. Don't forget to use the side of the wheel to get a flat surface. Would you mind making me a couple of sets while you're at it?
    Also, the streets are full of horizontal dropouts...
    BSNYC
    CB2
    CB2 is offline
    Jam Econo
    Reputation: CB2's Avatar
    5-bolt spider.
    Thanks,
    Sparty
    It's like hot dogs and hot dog buns.
    You need to buy 5 sets, so you have enough for 4 bikes!
    Don't have 4 bikes to use them on, send the extras to ME!
    I've ground bolts down too to make them work without a bash guard. With those it would be super easy because you could put the female side on a hex key to hold it against the grinding wheel.
    meh... whatever
    Reputation: monogod's Avatar
    Feb 2006
    truvative makes a set with 5 per pack for a couple bucks less than the cobalt.
    "Knowledge is good." ~ Emil Faber
    Out spokin'
    Dec 1999
    Quote Originally Posted by monogod
    Thanks. The AH pocket on the nut looks pretty deep... do you suppose by the time I ground those down (for SS use) adequate threads would remain? Hmmm... $25 plus shipping...
    Wish I could find some more of these...
    --Sparty
    disciplesofdirt.org
    Sparty, I remember seeing this setup before. Anymore pics? Is the rear spider setup still available anywhere? TIA
    meh... whatever
    Feb 2006
    take 1mm off each side on the grinding wheel. you can also use loctite "just to be sure".
    i can get you a set for $20 shipped.
    Out spokin'
    Dec 1999
    I got mine from Spicer Cycles several years ago. Another version is also available from Spicer.
    --Sparty
    disciplesofdirt.org
    Cool I did not even know this things exist, but for sure they makes perfect sense..
    You can also use Safety wire to prevent any trouble.
    Out spokin'
    Dec 1999
    Thanks, Monogod. Take a check?
    --Sparty
    disciplesofdirt.org
    Out spokin'
    Dec 1999
    Quote Originally Posted by patineto
    I followed the link in your sig to your motorcycle bike rack. Pretty cool.
    Here is my friend Bob's setup (click for larger photo):
    Looks like you guys even ride similar motorcycles.
    --Sparty
    disciplesofdirt.org
    Yes, Truvativ is the way to go. I just received these http://www.jensonusa.com/store/produ...+Bolt+Set.aspx and I could not be happier. Steel bolts with an alloy spacer for a single ring setup; 6mm back and 5mm front.
    Out spokin'
    Dec 1999
    Quote Originally Posted by SSchmoe
    Thanks. At $8.50 this looks like the way to go.
    --Sparty
    disciplesofdirt.org
    meh... whatever
    Feb 2006
    --Sparty
    i dont believe those are hex.
    meh... whatever
    Feb 2006
    this tool is great for regular slotted/hex bolts.
    locks securely into the rear slot and prevents spinning or stripping of the slot while turning the front ah.
    DAS
    DAS is offline
    Reputation: DAS's Avatar
    Good lord, Sparty, I have no idea what you are talking about. I'm so out of the loop! I mostly ride road these days. Well, I guess I ONLY ride road these days. How did I end up this way?
    Merry Xmas to your OR folks.
    Reputation: shiggy's Avatar
    Dec 1998
    Those are alloy bolts.
    If you are OK with grinding the nuts, Sparty, look at the steel "rock guard" bolts for $8 (or less ).
    https://aebike.com/page.cfm?PageID=3...ils&sku=CR2471
    mtbtires.com
    Yes they are hex and yes they are steel. Here is a bad picture that I think shows both. I bought 2 sets last fall and will likely buy 2 more sets this winter to replace chainring bolts for all my single ringed bikes. Finally no more bloody knuckles when changing rings
    Out spokin'
    Dec 1999
    Hey SSchmoe that's a pretty fuzzy magnet pic you got there but just so you know, I ordered 4 sets of those chainring bolts from Jenson. I like that they're steel (I'm convinced) and come with an alloy spacer so I don't have to cut 'em down if I don't want to. Also that there are 5 in the box... I've got old school cranks on all my bikes.
    Thanks for the input/link/proof.
    --Sparty
    disciplesofdirt.org
    Sparty, my LBS has had these for a couple of years, both black alum and SSteel, even in short lengths. I think it mostly comes from the BMX world. cost less than $10 I think. Have used them with moderate success, seemed to be a bit slippery on Surly SS rings, bent two rings bad when the bolts fell out. My fault for not checking when the bike was making a funny noise
    probably best to use some dried locktite on the threads, since you can get a good grip on the nut.
    bike ON
    bob
    red-haze
    The more I know the more I know I don't know.
    Let the bike ride the trail, you ride the bike.
    Look where you want to go, not where you don't want to go.
    Out spokin'
    Dec 1999
    Quote Originally Posted by red-haze.com
    ... locktite on the threads, since you can get a good grip on the nut.
    bike ON
    bob
    Will do, Bob. Thanks for the tip.
    --Sparty
    disciplesofdirt.org
    meh... whatever
    Feb 2006
    sweet! thanks for the clarification. just ordered a bunch for the shop from quality. generally they are listed as hex in the description, but for some reason are not. no more grindy!
