help picking a crankset- Mtbr.com
Results 1 to 13 of 13
    Oct 2010
    I am brand new but ambitious and I need some advice. I was given a Univega Frame and plan on making a singlespeed.
    What would you suggest for a crankset for this square tapered bottom bracket?
    thanks
    Low Rep Count
    Reputation: 1SPD's Avatar
    Honestly, I think I would just pick up a new bb for about $30. I am thinking that I would find a crank that you like and then get the bb you need to make it work. A good starting crank for a SS is a Shimano STX. They can be picked up used for pretty cheap via Craigs list or Ebay. However, if you want to keep this bb, then you may need to take it to a shop and have it measured as different cranks tend to take different length bb's if you will. I could be wrong on that last part so hopefully someone will chime in. But I do know that from my roadie days that a Campy crank will not fit the square taper of a Shimano bb.
    Super Moderator SuperModerator
    Reputation: driver bob's Avatar
    None. Pull that loose bearing POS out of there and replace it with an inexpensive sealed unit.
    Oct 2010
    thanks - I will look at finding a new BB to match the Shimano STX
    Out spokin'
    Dec 1999
    Quote Originally Posted by driver bob
    This is good advice. You certainly want a spindle that is drilled and tapped to accept screw-in bolts rather than the nut-on type in your photo. The type you've got are notorious for loosening up all by themselves.
    You can get a good quality, new sealed bearing BB like this Shimano UN54 for ~$20:
    http://www.jensonusa.com/store/produ...m+Bracket.aspx
    --sParty
    disciplesofdirt.org
    one chain loop
    Reputation: fishcreek's Avatar
    is that a road frame? wanna see.
    everything sucks but my vacuum cleaner.
    CB2
    CB2 is offline
    Jam Econo
    Reputation: CB2's Avatar
    If I need a crank, I'd consider this LX crank and BB converted for singlespeed use. I think it's a pretty good deal at$129.95.
    +1 on the LX crankset/bb. Remove the kickstand too.
    master blaster
    Reputation: veloreality's Avatar
    truvativ stylo 1.1 for the win.
    best ss cranks for the money.
    i run them on my high end bikes that justify xtr.
    Reputation: gord962's Avatar
    +1 on the Stylo OCT 1.1. I am currently building my first SS and this has been getting the best reviews in the price range. I will be ordering these if I don't get them under the tree in three weeks from now! Best price I have found so far is from Pricepoint.
    If you want all the comforts of home, stay there.
    Rides, Reviews, Races and Random Thoughts
    Reputation: madsedan's Avatar
    Aug 2010
    I just got a stylo 1.1 and a bottom bracket mounted Mrp 1.x chain guide and love it, I will use it on my next bike as well, price for the stylo gxp I got was $130 from my lbs, but you can find online for close to $100 and that includes a nice outboard bearing sealed gxp bb and a slick bash guard if you need it.
    Hardrock 29er, Niner EMD9, Cannondale F29, Camber Expert, 650b Nickel all gone.
    2014 Giant Anthem 27.5 here.
    Retro Grouch
    Reputation: aka brad's Avatar
    Quote Originally Posted by CB2
    Your may want to go elsewhere than the LX crank; it looks to be more of a downhill crank as it is only available in 170mm.
    <a href="http://www.pricepoint.com/detail/14316-100_TRUSS5-3-Parts-56-Cranks/Bolts/Truvativ-1.1--Guard-Stylo-Single-Speed-Crankset-2010-offer?utm_source=Googlebase&utm_medium=datafeed&ut m_campaign=FTP&offer=IN210GLB.htm&zmam=3075515&zma s=1&zmac=30&zmap=100%20TRUSS5">Pricepoint</a> has the Stylo on sale for $115.00.
    Just one more rep and I get the toaster!
    Oct 2010
    thanks all!
    Quote Originally Posted by fishcreek
    it is a mtn bike. I will post a photo later.
    Quote Originally Posted by erichwic
    kickstand is gone
