Help..need to get gears on my SS- Mtbr.com
Results 1 to 15 of 15
    Reputation: Francine's Avatar
    Broke my tibia/ fibula with surgery this summer. The SS is not working for me right now. I have some other bikes to ride, but I like the fit of my IF SS. How can I add some gears? I want to do the 1 x 9 thing. I have searched for an add on derailer hanger to no avail. Any ideas?
    What type of dropouts do you have? The have what axles like an axle tensioner but has a derailleur hanger coming off of it. This works if you have horizontal dropouts. If you have sliders, you need a new drive-side slider from Paragon. The next step is gears. Do you have a full cassette body on your rear wheel, is it an SS cassette body, or do you have a freewheel? If it's a freewheel, you'll need a new rear wheel (and if you do that, maybe just go with an Alfine and skip the derailleur hanger). If it's a full cassette body, just add a cassette. If it's an SS cassette body, you'll have to break apart a cassette and add 4,5, or 6 gears depending on the cassette and the width of the body.
    We need to know what type of dropouts you have and what rear hub.
    more info
    The frame is an Independent Fabrication with an eccentric BB. I have a rear wheel and shifters just need a rear hanger somehow. Looks like this.
    Paste eater
    Reputation: Jwind's Avatar
    Mar 2006
    EB and no hanger, that's a tough one. I think your SOL...
    Jan 2005
    saint/hone?
    If you are willing to build a new wheel, you can use a Saint or Hone axle-mounted derailleur. They require a saint/hone rear hub.
    Or a internal geared hub
    Reputation: BassBikerD's Avatar
    I just broke my fibula about a month ago.....how long before you could even think about gettin' on a bike?
    Sweep the leg!
    Reputation: Caffeine Powered's Avatar
    Mar 2005
    Quote Originally Posted by rangeriderdave
    Internally geared hub is the only way that frame will go multi speed.
    Authorities speculate that speed may have been a factor. They are also holding gravity and inertia for questioning.
    organically fed
    Reputation: w00t!'s Avatar
    Quote Originally Posted by Caffeine Powered
    Why not the Saint?
    Saint would work fine. Either way it will need a new wheel. I'd just go internal gear hub. No cable stops on that frame anyways.
    Frt Range, CO
    Reputation: pursuiter's Avatar
    Easiest way to go is an Alfine or i-Motion 9:
    Sweep the leg!
    Mar 2005
    Quote Originally Posted by w00t!
    Why not the Saint?
    Because then it will still sound like a SS.
    Reputation: wickerman1's Avatar
    Quote Originally Posted by pursuiter
    pricey though isn't it? For temp use Shimano makes a Nexus hub that has good reviews and its 8spd and cheap.
    Frt Range, CO
    Quote Originally Posted by wickerman1
    Alfine hub/shifter runs ~$260, the Nexus can save ~50 for the cheaper one the better version is only a few dollars less than the Alfine (has the same guts). Nexus doesn't have a factory disc brake option.
    those are Rollercams...
    Reputation: WTB-rider's Avatar
    If it's a temporary fix, how about one of these? You can definately run 7 speed with this, maybe 8.
    Truly a wealth of useless information.
    http://blackdogadventureteam.blogspot.com/
