Help me turn this into a SS...- Mtbr.com
Results 1 to 15 of 15
    w3rd.
    Reputation: Purple Liquid's Avatar
    Dec 2005
    the cheapest way possible.
    <img src="https://i26.photobucket.com/albums/c121/Sick_Purple_Liquid/BIkepictures021.jpg" alt="Image hosted by Photobucket.com">
    I don't want to change out the fork, or handlebars, seatpost etc.
    I just want a nice working ss that won't be a pain to maintain.
    and yes, I am getting new pedals. My dad never rides this bike anymore, so I'm gunna have some fun with it instead.
    Thanks alot!
    All 26.5" all the time!
    Reputation: Zanetti's Avatar
    Adjust the derailleur travel screws to lock the bike in one gear and remove the shifters and cables. That's about a simple and cheap as it gets.
    Time to go farther
    Quote Originally Posted by Purple Liquid
    Don't shift? haha.
    Just kidding. Take apart the crankset and run just the middle ring. Get a BMX cog for the rear in the "magic ratio" and shorten the chain. Space the cog with PVC.
    If that's too cheap then add parts (spacer kit, nice cog, nice front ring, tensioner) as money allows. FWIW I rode my Fuel as a SS on several rides by just not shifting to see if this whole SS thing was interesting. It was so now I have a 2006 monocog frame to build up.
    No Justice = No Peace
    Reputation: Lutarious's Avatar
    Feb 2005
    yup
    Lose the shifters, derrailleurs, cables etc. Run your big ring as a Bash Guard and you won't need to buy shorter chainring bolts. Use PVC spacers and buy a nice rear cog. I like endless, but Surly's are nice too. ($30) When you wear out your chain ring, buy a sturdy one with no ramps and pins. They work better and cost the same. ($25) 1/8th inch chain is also a good investment, when the time comes. ($15)
    The best tensioner so far is a Rennen Rollenlager, which are a little hard to find, but they are worth it. Magic ratios and spring loaded tensioners are sloppy at best. If you can't afford an ENO hub, use a Rennen. It pays to buy a decent chain too.
    Around $100 should get you rolling in style. Enjoy.
    "Welcome to my underground lair...."
    Strongbow or Bust!!!!
    Reputation: The Tractor's Avatar
    Can we see the drive-line side please?
    for about $30-35 will get you a new chain (1/8" KMC Z chain) and this kit:
    http://www.jensonusa.com/store/produ...rsion+Kit.aspx
    If you want you can get this for your chain tensioner:
    http://www.jensonusa.com/store/produ...ingleator.aspx
    Just some suggestions that I know of for under $100
    Rob
    Fermented Apple Juice rules!!!!!! BURRRRPP!!
    w3rd.
    Dec 2005
    Drive Train shots
    Quote Originally Posted by The Tractor
    https://www.jensonusa.com/store/prod...rsion+Kit.aspx
    https://www.jensonusa.com/store/prod...ingleator.aspx
    Rob
    Hope these help:
    <img src="https://i26.photobucket.com/albums/c121/Sick_Purple_Liquid/Dadsbikephotos001.jpg" alt="Image hosted by Photobucket.com">
    <img src="https://i26.photobucket.com/albums/c121/Sick_Purple_Liquid/Dadsbikephotos002.jpg" alt="Image hosted by Photobucket.com">
    <img src="https://i26.photobucket.com/albums/c121/Sick_Purple_Liquid/Dadsbikephotos004.jpg" alt="Image hosted by Photobucket.com">
    <img src="https://i26.photobucket.com/albums/c121/Sick_Purple_Liquid/Dadsbikephotos005.jpg" alt="Image hosted by Photobucket.com">
    I'm sticky
    SS at no cost...
    For no cash...
    1. Remove the shifters, cables, and front derailleur.
    2. Remove links from the chain to shorten it.
    3. Screw in the limit screws on the rear derailleur (now the chain tensioner) so it doesn't move from the gear you choose.
    4. Remove the cranks and remove the inner chainring, put cranks back on.
    For a minimal investment...
    1. Remove the cassette, break it open, and remove the cog you want to use.
    2. Get a small amount of PVC and use it (and the cassette spacers) to hold the cog inline with the chainring.
    A little more cash...
    Add a real tensioner of some sort (Surly Sinlgeator, etc.).
    lover of trees
    Idea!
    Thanks for this thread...I'm in the process of converting my ghetto ss into a proper one and wasn't exactly sure what direction I wanted to take....but anything in here will be an improvement from what it is now.
    Feb 2005
    Bikeman.com
    Sells KMC rustbuster chain for like $9.00. Best deal going, nice nice guys,
    those Mainers... I tell ya!
    Crank q fer ya......
    Check and see if the middle ring is bolted to the small bolt circle or if it is press on like the big ring.
    rob
    w3rd.
    Dec 2005
    rob
    It's pressed on,
    Reputation: Mudflaps's Avatar
    It's pressed on,
    Just run the chain in the middle chainring of the crank for now. When you decide you really like this riding style, get a different crank that has changeable rings, and consider a 180 mm crank when that is so. Then follow some of the other suggestions already posted in this thread. Have Fun!
    Rollin' a fatty Moderator
    Reputation: DiRt DeViL's Avatar
    It's pressed on,
    You have a couple of options with the cranks.
    1) Leave them as they are and run in the middle ring, just in case you decide to go back to gears so no harm no foul.
    2) If you don't plan to use gears anymore you can grind the teeth of the big ring and use it as a bash guard. Also remove the granny or grind it too.
    3) Get a cheap used crankset and leave only the middle ring in the middle or outside position.
    One gear to rule them all
    Reputation: 32seventeen's Avatar
    Caution;  Merge;  Workers Ahead!
    Why would you say this....
    Quote Originally Posted by Lutarious
    I won't tell my wife, she has been riding/racing a bike with a magic ratio for three years. She hasn't had a single problem, yet.
    I rode a singulator, in push up mode,on my first convert for about a year, no problems.
    Todd............. If you can't be kind, at least have the decency to be vague
    w3rd.
    Dec 2005
    Thanks alot guys!
    I'll post pictures when this puppy is done
    Thanks again!
    JM
