Has anyone used a Surly 1 speed converter- Mtbr.com
Results 1 to 6 of 6
    XC Geek
    Reputation: AZ Steelhead's Avatar
    Do these work very well? I'm thinking of using one, anything I need to know?
    Appalachian Singletrack'n
    Reputation: Endomaniac's Avatar
    Someone asked the other day, I replied....
    I use one to convert an Ultegra hub to fixed gear. It is an ingenious little devise. Its very well made and thought out. It takes about 5 min. to install although you may wind up playing around with the spacers some to get the wheel dish right. I donít know why you would use one to mount a freewheel though. Spacing a cog out on the freehub body would be allot cheaper and better quality bearings than most BMX style freewheels.
    Reputation: Nater's Avatar
    What's the desired result?
    Unless you want to go to a fixed gear, I don't think the fixxer is neccessary. It's rather expensive when if all you want to do is convert a cassette hub to SS use. I'd go the single cog/spacer route and possibly put a solid axle in if you have wheel slippage problems. Otherwise I don't have any experience with the product...if you've ever taken your freehub body off of your hub, I think that installation should be fairly straight forward.
    XC Geek
    The wheelset I want to use has an aluminum freehub body, I'm thinking that won't work very long with a cog and spacers.
    The Fixer only works on Shimano hubs. I was unaware Shimano made any aluminum Bodies I thought they only did steel and Ti.
    If you just want to run SS a King cog is much cheeper.
    If you want to go fixed the Fixer rocks.
    Reputation: Sid6.7's Avatar
    I'm running the Fixer on a Shimano Deore hub. Works great if fixed gearing is what you want.
  1. New Surly Pacer's maiden voyage yesterday...
    By Stick in forum Riding Passion
    Last Post: 10-01-2004, 01:46 PM
  2. 9 speed derailueller w/ 8 speed cog?
    By singletrackfrog in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-10-2004, 08:49 PM
  3. 5 bolt / 8 speed / 20t
    By Legbacon in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-09-2004, 10:51 PM
  4. Using factory made wheels on a single speed
    By Dimitri Nikas in forum Singlespeed
    Last Post: 01-31-2004, 03:23 PM
  5. 7 speed compatable with 8/9 speed
    By philze in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-28-2004, 10:02 PM
